Parking Brake Control |
Jan 26, 2011 - 7:04 PM |
Does anyone know what the Parking Brake Control is?!
I'm redoing my whole parking brake setup because one side partially froze on me and I'd rather have brand new stuff before my manual swap. I know I need the front cable, both left and right rear cables, and the shoes with the internal components as well. On Conicelli it mentions something about the Parking Brake Control, which is $123. So does anyone know what it is because I don't want to buy it if I don't have to. |
Jan 26, 2011 - 7:20 PM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Maybe they mean lever?
Jan 26, 2011 - 7:31 PM |
I'm not sure because it's listed in order from front to rear: front cable, parking brake control, rear cables, shoes.
my god. $250 just for the cables and shoes. FML. This post has been edited by mkernz22: Jan 26, 2011 - 8:12 PM |
Jan 26, 2011 - 9:16 PM |
What usually locks is the joint that connects the shoe and the long metal piece that's connected to it. Shoes should be enough and don't forget to grease every fastener/joint and any other moving part in that area.
Jan 26, 2011 - 9:42 PM |
well i took it apart and reassembled the shoes, adjusted them and it was still semi locked.
I took everything out internally so i have nothing on the drivers side. one of the bolts snapped off the cable where it goes into the housing so I will need a new cable |
Jan 27, 2011 - 11:48 AM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
the drum is usually what holds the ebrake, look in there for the thing that looks like a screw with notches in it, you can spin it to tighten, but to loosen you must release the pressure on it and pull the other way, its quiet a pain in the arse
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Jan 27, 2011 - 12:19 PM |
well i mean inside the drum on my drivers side, there is nothing in there at all. i took everything out just because it was partially locked and it would lock up on snow and ice. the cable is just roped up to the knuckle or something lol
i just need a new cable and new shoes on both sides. I don't think the shoes have ever been replaced |
Lo-Fi Version | Time is now: December 3rd, 2024 - 1:13 AM |
