> Nolethane / Urethane bushes, Where to find ??
post Jan 28, 2011 - 9:01 PM
basho
Joined Sep 26, '10
From Surfers QLD Australia
I want to rebush my suspension and I've been looking for Nolethane / Urethane bushe sets and it's driving me nuts, I'd have to have found bushes and master bush kits for evey model of Celica ever made going back to before god was invented --except the good ole ST204.
The only one I've found is this one http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...E:X:RTQ:GB:1123
This comes from Poland and is advertised on the UK Ebay and runs out at around $340.00-$350.00 ish (depending on the exchange rate on the day) at the door which, though probably cheaper than new OE, (what ain't) still seems exy when , for example, you can pic up a master Kit for a GT4 for 80 odd bucks in the US.
Also is the question that this is advertised as being good for the ST202 - ST204 and I have read that there are some dimension differences in the bushes beween these two models.
So does any oone know where I can find the bushes I'm after , and has anyone bought the Polish ones and how did you go ?
post Jan 29, 2011 - 12:25 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
I have a set of the polyurethane bushings you posted the link of. I have an ST204, and I had no problem fitting them in. The only difference I see there being is for the st202 SSIII Celicas with superstrut suspension. Yes, they are a bit exspensive, but considering there is no one else making polyurethane bushings for the Celicas, that would explain the price. I have no regrets installing these.
post Jan 29, 2011 - 9:31 PM
basho
Joined Sep 26, '10
QUOTE (MaskedMan @ Jan 29, 2011 - 12:25 AM) *
Fantastic, thanks for the reply, looks like this is the go then, I'll have a quick look at my moding budget, -ah -hem , might have to raise a levy,-- laugh.gif
post Feb 2, 2011 - 8:42 AM
quick_5hifter
Joined Mar 13, '09
From Constanta, Romania
Hello,
Excuse me if I'm not supposed to ask this here, but it's about the same manufacturer (from Poland) and the same material (polyurethane): I want to know a few things about the polyurethane ENGINE MOUNTS.
I've seen they come in two shapes: full design and "turbo" design, first one being recommended for racing and the other one for street/racing (softer than full design). Anyone tried any of these so far? The seller/manufacturer says that they might cause some vibrations inside the cabin, how bad are these vibrations? Do both types of engine mounts cause vibrations? Are these two engine mounts enough to reduce/eliminate engine "movement", without replacing the third (gearbox) mount? (this is about the european ST202, non-superstrut).
Din anyone contact this guy some other way then via ebay? (I'm asking this because I'd rather go get the bushes myself from him, since Poland is ~1000 km away from me, instead of ordering them on ebay, have them shipped to UK and then back to my country).
Thanks and excuse my intrusion!
post Feb 2, 2011 - 9:56 AM
basho
Joined Sep 26, '10
Maybe try contacting him through Ebay and ask for a phone No, my guess is that the engine mount bushes are very firm and transmit the engine vibration , is an engine shock brace available for these ST202/4 's ?? that'd cure the engine movement without hardening up the mounts , how about TRD mounts are they available ?
I did the body end of my trailing arms today, Pedders (Southport QLD) came to the party and found some Nolathane ones very close and customised them to fit and pressed the old out and the new in , I fitted the arms out/in total cost $62.00, big ride difference , I didn't expect much and was suprised.
Just to note the bush size at both ends of the trailing arm are the same, that is the one that presses into the trailing arm and the one in the hub that the u end of the trailing connects to.
So if you ware replacing with OE you could use a new OE hub end bush in the eye end of the trailing arm which would save you paying $237.00 each for new trailing arms which is what Toyota will want you to do.
Now I have found Nolathane bushes I will have Pedders do the hub end as it's a bit more tricky, it'll cost me $140 but still cheap I'm not worried about the suspenion arms at the moment as the OE are all good .
The front kit I can get here a fair price and given the suprising improvement just the front trailing arm bushes made I'll be getting that done ASAP-- and the budget allows. laugh.gif
Ill post up the Pedders part Nos and the bush dimensions that it needs modding to tommorrow for anyone thats interested.
Lo-Fi Version Time is now: January 11th, 2025 - 6:47 AM
