> antenna removing??, How to
post Jan 29, 2011 - 9:12 AM
Seztor
Joined Mar 23, '08
From Denmark
How to pull this son of a bitch down? I removed two srews from inside behind the plastic.
[font=CELICA FOREVER][/font]
post Jan 29, 2011 - 9:24 AM
the slotted peice around the antenna is threaded, put a few layers of tape down around the antenna, and use a flat head screwdriver, put it in a slot, and tap it counter-clockwise to loosen it.
there is a special tool made to remove it, but 99% of people use the method discribed above.
(i use the tape to protect the paint, just in case you happen to slip with the screwdriver, just dont whack it hard...slow and easy.)
post Jan 29, 2011 - 11:17 AM
Seztor
Joined Mar 23, '08
From Denmark
oki presure2 u mean that i need to put the screwdriver inside the antenna hole from the outside and then twist the antenna from inside while the screwdriver is in the hole?
post Jan 29, 2011 - 10:55 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
post Aug 13, 2013 - 4:38 AM
Jeebus
Joined Apr 21, '13
From YYC
Good thread. Just what I needed.
Can these style antennas simply be screwed in afterwards?
post Aug 14, 2013 - 5:00 AM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
QUOTE (Jeebus @ Aug 13, 2013 - 2:38 AM) *
If you're going to install that antenna then follow THIS thread.. it's for an s2000 antenna but same concept
post Aug 20, 2013 - 1:43 AM
Overkill
Joined Jul 27, '04
From Houston
QUOTE (smkr3w @ Aug 14, 2013 - 10:00 AM) *
There is an easier way to do it and it does not include glue. Read close to the last entry if interested.
http://www.6gc.net/forums/index.php?showtopic=66366
post Aug 22, 2013 - 3:19 AM
Jeebus
Joined Apr 21, '13
From YYC
Overkill, you said that you bought an antenna from a 2000 Celica, but which part was that? I'm looking around on ebay, and there's the stubby kinds, the motorized antenna unit, and some aftermarket stuff.
(Now that I'm searching tonight, looks like there's some more likely possibilities showing up.... of course....)
Stuff like this?
example 1
Or This?
Or perhaps this?
I realize you went to a junk-yard to get it, but I have no car, so I'm doing this all from the seat of my desk.
Thanks for the info!
post Aug 22, 2013 - 10:41 AM
Overkill
Joined Jul 27, '04
From Houston
QUOTE (Jeebus @ Aug 22, 2013 - 8:19 AM) *
Jeebus, The part from the 2000 celica was everything except the mast. Basically if you find a salvage yard with a celica that has the antenna still... all you have to do is unscrew the silver nut piece on top, and unbolt the interior piece from inside the fender (to get to it, you have to go through the hatch or tail light). Make sure you get the silver nut piece, and the black piece that sits under it. In one of the threads that I posted, there is a way that you can bend the bracket that bolts to the interior so that it will now fit the 94-99, however I simply left that alone and did not bolt it. There isnt much to the lower portion of the antenna, so I simply tightened the silver nut like it was on the 2000 celica and it holds its location just fine. My radio reception is 100% better and I love the way it looks.
*Edit* this might help... you will only need items #2, #3, #4, & #5
This post has been edited by Overkill: Aug 22, 2013 - 10:56 AM
post Sep 21, 2013 - 6:08 AM
rentaspace
Joined Sep 23, '12
From Australia
Re-located mine to the roof, bought a $12 shark-fin antenna and a $5 antenna extension... tongue.gif $17 and and hour and a half later, my antenna was mounted on the roof and my OEM one disconnected tongue.gif
post Sep 21, 2013 - 12:31 PM
yellowchinaman
Joined Aug 11, '08
From London
Use a pair of thin plyers and slot it in opposit ends. Turn it out.
Inside behind the boot plastic, unscrew the motor with a 10mm socket and the power cable and antenna cable just unclips.
I removed mine and ran it up to the roof lining and used an amplified hidden antenna strip so mine is never seen.
post Sep 22, 2013 - 3:50 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
What about a sharkfin like this Ray on the roof?
http://www.ebay.co.uk/itm/140870266936?ssP...984.m1438.l2649
post Sep 23, 2013 - 8:17 AM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (jeffrosie @ Sep 22, 2013 - 4:50 PM) *
Yeah that can work.
You just need to extend the antenna cable and power cable to the roof and drill a hole.
I didn't want to drill a hole so I kept mine hidden with one of these behind the head lining
http://www.ebay.co.uk/itm/Car-Hidden-Inter...=item35be03b266
post Oct 15, 2013 - 10:02 PM
Jeebus
Joined Apr 21, '13
From YYC
Hey,
as I was wiring in my DRL to my cig lighter power source, I was taking a look behind my console for the wiring mess that the previous owner left me when he took out his 7" touchscreen stereo and replaced it with a Hyundai deck that didn't work. Now, I'm assuming that the stereo didn't work because the harness is all fubar, and the radio didn't work because I couldn't find the antenna cord that plugs in.
is this black wire beside the ebrake the antenna plug-in cord? If so, I've got a lot to do before I get any stereo working in my car. : /
post Oct 15, 2013 - 11:21 PM
Overkill
Joined Jul 27, '04
From Houston
Jeebus - It looks like it to me.
Lo-Fi Version Time is now: December 2nd, 2024 - 5:34 AM
