> Celica ST - C52 Tranny ... 4.311 or 3.722 Final Ratio??
post Jan 29, 2011 - 5:39 PM
h4rfang
Joined Dec 11, '10
From qc
hi i have bought a '94 Celica ST with C52 Tranny last year and I am currently changing the input shaft bearings (rear and front) because they were worn and the no.2 shift fork because because it was very worn causing 3rd gear pop-out...
i know the C52 can be found in these cars:
Toyota Celica
Toyota Corolla (E90) GTS
Toyota Starlet GT Turbo
Toyota AW11 MR2
Toyota Corolla Levin AE101 / Toyota Sprinter Trueno AE101 - early years
Geo Prizm (1990-1992)
And maybe more...
apparently all AW11 MR2 have the 4.311 Final ratio and the FWD cars can be found with both ratio: 4.311 and 3.722...
i want to know if the '94 celica have the 4.311 Final Ratio or 3.722 Final Ratio?? and how to know if i really have the 4.311 or 3.722 final ratio???
THANK YOU!
post Feb 1, 2011 - 2:25 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Im thinkin it has to be 4.311 as 5th gear is pretty long gear in this tranny.
post Feb 1, 2011 - 3:48 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
http://en.wikipedia.org/wiki/Toyota_C_transmission
post Feb 2, 2011 - 10:16 PM
97lestyousay
Joined Jul 7, '03
QUOTE (BonzaiCelica @ Feb 1, 2011 - 12:48 PM) *
That lists corollas, according to wiki the celi has a c56.
JDM guy made me do it.
post Feb 2, 2011 - 10:33 PM
BonzaiCelica
Joined Apr 24, '08
haha dude I'm right I'll bet you anything. It lists c56 and celica under it because they are referring to the c56 transmission bolted to the 1zz-fe engine. I can bet you that for sure. also it lists the mr2 spyder which was the mr2 produced from 2000-2005. I have the chilton book and it says c52 tranny in it as well. I just dont want to take a pic of it waste of time kindasad.gif
post Feb 2, 2011 - 10:43 PM
97lestyousay
Joined Jul 7, '03
I own an 88 corolla gts with a c52, and a 97 celi with a c52, and I can tell you first hand the corolla is lower geared than the celica. wink.gif jus sayin smile.gif
post Feb 3, 2011 - 6:07 PM
h4rfang
Joined Dec 11, '10
From qc
thank you for all the answer! ... i have my tranny removed from my celica. the transmission is open in the garage...
how to calculate the gear ratio?
i think that is like that:
Count the number of teeth on the ring gear.
Count the number of teeth on the first gear.
Divide the result of your first gear counting by the result of your engine gear counting. This is your first gear's ratio.
Repeat this process for every following gear.
anyone know if it is the correct way to calculate the gear ratio???
post Feb 3, 2011 - 9:40 PM
BonzaiCelica
Joined Apr 24, '08
we have a c52 transmission. no reason to waste your time and count each teeth. Its listed on wikipedia just as I posted. So if your bored and you want to then go ahead
post Feb 3, 2011 - 10:33 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Because wikipedia is always factual rolleyes.gif.. And it's tooth*..
I'd count the teeth just to insure the info for the website!
post Feb 4, 2011 - 10:11 AM
azian_advanced
Joined Apr 18, '05
From Calgary
if by ring gear you mean the splines in the engine (or the splines on the tip of the shaft), then that's wrong.
you'll need to find out which of the gears mesh for each gear (1,2,3,4,5,Reverse). in first gear, two gears are in mesh.. one from each gear shaft.(example)
just count the number of teeth from one gear and the number of teeth of the gear in mesh on the second gear shaft.
take the larger number and divide it by the smaller number. that's the gear ratio.
This post has been edited by azian_advanced: Feb 4, 2011 - 10:20 AM
post Feb 4, 2011 - 10:18 AM
azian_advanced
Joined Apr 18, '05
From Calgary
forgot to add, the gear on the input shaft (the one with the straight cut gears) is the reverse gear. so first gear would be the large helical gear next to it.
This post has been edited by azian_advanced: Feb 4, 2011 - 10:21 AM
post Feb 4, 2011 - 6:16 PM
97lestyousay
Joined Jul 7, '03
http://www.6gc.net/information/9
post Feb 4, 2011 - 8:24 PM
BonzaiCelica
Joined Apr 24, '08
post Feb 5, 2011 - 8:51 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
QUOTE (BonzaiCelica @ Feb 4, 2011 - 5:24 PM) *
post Feb 6, 2011 - 3:33 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (SupraKid @ Feb 5, 2011 - 8:51 PM) *
ha ya you know what, maybe I will buddy. I'll be seeing you at the meet, this isn't the last you'll hear from me laugh.gif
Lo-Fi Version Time is now: December 3rd, 2024 - 7:08 AM
