7A-FE perormane |
7A-FE perormane |
Jan 29, 2011 - 7:46 PM |
Enthusiast Joined Jan 11, '11 From Hollis Maine Currently Offline Reputation: 0 (0%) |
I have the 7A-FE in my celica and dont want to do a engine swap so I was wondering if anybody has found performance parts for it becuase i havent really found any.
Jan 29, 2011 - 9:34 PM |
Enthusiast Joined Oct 4, '09 From Pomona, CA Currently Offline Reputation: 1 (100%) |
I have the 7A-FE in my celica and dont want to do a engine swap so I was wondering if anybody has found performance parts for it becuase i havent really found any. There's not much you can do besides Turbo to really get to perform. check out smaay's post he makes a custom kit for it. Mine came out awesome, its pretty fast now and lots of fun -------------------- The heart has its reasons which reason knows nothing of
2000 7th gen GTS 6spd 95 st, swapped 3sgte 3rd gen wrc version :D |
Jan 29, 2011 - 9:56 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
7afes arent performance engines, sorry eyrnn . Even if you turbo them ull be lucky to get 200hp, it'll cut the life of the engine in half AT LEAST(if you dont rebuild), and youll spend about the same as it would be to swap...
This post has been edited by SupraKid: Jan 29, 2011 - 9:56 PM |
Jan 29, 2011 - 10:48 PM |
Enthusiast Joined Oct 24, '09 From Appleton, Wisconsin 54915 Currently Offline Reputation: 7 (100%) |
Agreed, not much unless you turbo or swap.
Simple things you can do though.
More in depth for a bit more power can include.
I have a 5SFE and i don't plan on turbo until i squeeze every bit of power out of an N/A build. If you want to pull every bit of power out of your motor i would suggest you do alot of research and ask questions when you need to. There's alot of information out there and what i just said is only the tip of the iceberg when it comes to performance. |
Jan 29, 2011 - 11:15 PM |
7afes arent performance engines, sorry eyrnn . Even if you turbo them ull be lucky to get 200hp, it'll cut the life of the engine in half AT LEAST(if you dont rebuild), and youll spend about the same as it would be to swap... Kid, you have no idea what you are talking about. yes the 7A is not a performance engine but its actually a pretty stout engine. it will handle a turbo with no problems if you treat it right -------------------- 2001 Celica GT-S Turbo
Jan 29, 2011 - 11:17 PM |
Jeff, the 7afte(on this site) has NEVER taken over 230hp, if you have something to back up your claims that the 7afe is indeed a strong boosted engine that can actaully put some power down(comparable to a 3sgte or 4agte) then i would REALLY like to see it.
I NEVER said the 7afe cant handle a turbo reliably.Most ppl will boost a 7afe that has never been rebuilt, and on an engine thats AT LEAST 10 years old its not gonna last as it would if it was NA..Re-read what i said. This post has been edited by SupraKid: Jan 30, 2011 - 12:09 AM |
Jan 30, 2011 - 11:22 PM |
Enthusiast Joined Apr 25, '07 From Tri-cities WA Currently Offline Reputation: 0 (0%) |
If you go the route of a 7agte some have made well over the 230 mark. Here is a copy and paste of someone who has (Nik)
7agte dyno high boost 382 whp 369 trq at 23 psi on 92 pump gas Although like many have said before its a costly route to go. |
Jan 30, 2011 - 11:29 PM |
Nik has spents over $15,000 on this engine.
This post has been edited by SupraKid: Jan 30, 2011 - 11:29 PM |
Jan 31, 2011 - 5:33 AM |
Enthusiast Joined Jul 3, '09 From UT Currently Offline Reputation: 14 (100%) |
I dont think ive seen anyone with a 7A and a FE head go much above 230 hp.... The 7AGTE is a whole different motor. That setup can handle all sorts of power if you build it right. I remember posting about some guy who sold engines for JDM Corollas that made ~500 hp.
http://www.twincam.org/topic/18070-7agte-b...ae92-levin-gtz/ If you have a stock 7A, i wouldnt expect big numbers. Youd probably be lucky to hit 230 on a 10 year old engine with no modifications. Check this thread out for some tips if youre interested. Its got tons of info on the 7AFTE build. Those folks up at the "turbo factory" in New England really know their stuff. http://www.6gc.net/forums/index.php?showto...44&hl=7afte This post has been edited by zonz540: Jan 31, 2011 - 5:41 AM |
Lo-Fi Version | Time is now: January 10th, 2025 - 1:39 PM |
