23 Pages V  « < 3 4 5 6 7 > »
> Timmyface's progression, The End of an Era..
post Dec 9, 2011 - 7:51 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Please enlighten me further on these smaller bolts and washers and how they work haha.
I dont know how much degree i need, but i want it like 1inch more positive thats all.
post Dec 19, 2011 - 3:34 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
.. Getting there..slowly
Before:
After^
Not much of a change, but it's noticeable i guess.
I also raised the rear about 1cm to try get a bit less camber, but didn't effect it much.
Not quiet sure if it was worth it yet haha. May buy another set for the lower bolts... or bigger spacers tongue.gif
This post has been edited by Timmyface: Aug 4, 2012 - 6:18 AM
post Dec 19, 2011 - 5:51 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
ROFL pedo bear.. My friend wants that sticker on his Accord.
Grade 10 bolts my friend. Anything in smaller diameter than the stock ones with grade ten washers. Use it up top and you're golden.
post Dec 19, 2011 - 11:21 PM
UndecidedPC9397
Joined Dec 15, '11
From minnesota
Your car is very well executed, props, man! I have a 97 celica gt with the same color. hope I can make clean and flawless too! but still got a good chunk of work ahead of me. And just out of curiousity, what did you do with your antenna? did you fill in the space of the boot? cuz my anttenna's tracks wore out so it was stuck up and got knocked off and to my surprise found the radio still works fine and was thinking of either getting another anttenna mast or finding a way to fill the hole in with something better than electrical tape.
post Dec 19, 2011 - 11:39 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
QUOTE (UndecidedPC9397 @ Dec 20, 2011 - 3:21 PM) *
I havn't done anything with my antenna? With my headunit, I used my antenna cable to turn my amp on, as I don't really use the radio. But it still works fine for me also.
Your best bet is to either bog it, and fibreglass over it and paint, or fry make a circle covering out of plastic or fibreglass?
I still have my antenna, its just never up haha.
And rabid, I may try locate some grade 10 bolts, and put the camber ones on bottom.
Just the idea of a smaller bolt to me, allows more room for the hub to slip and be loose.
post Dec 19, 2011 - 11:44 PM
UndecidedPC9397
Joined Dec 15, '11
From minnesota
QUOTE (Timmyface @ Dec 19, 2011 - 11:39 PM) *
Ohhhhhhh lol my bad then, im probably gonna end up getting an antenna to replace my buchered one from a junk yard, praying ill find one somewhere! but yeah if it was a perfect world, I would get rid of that but I just cant take that on right now. but yeah I know how, just cant do it right now. I still need to repaint my new door sitting in the garage and fix a little bit of rust on my hatch then I get to the real fun stuff smile.gif , still deciding if I should refinish my stock alloy wheels or get some aftermarket ones
This post has been edited by UndecidedPC9397: Dec 19, 2011 - 11:46 PM
post Dec 21, 2011 - 6:52 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
I wish my car came with stock alloys. I'd rock them for a bit... especially next week, as im possibly changing the color of my rims, and will have to use my' Steelies' for a day or so haha
post Dec 21, 2011 - 3:50 PM
UndecidedPC9397
Joined Dec 15, '11
From minnesota
Ohhh steelies laugh.gif I need to get some with winter tires (I live in minnesota, nuff said) and that will give me time to clean up my stock wheels and get matching tires maybe
post Dec 23, 2011 - 6:43 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
It won't slip if you run hardened washers. It's the same as your normal bolt.
Camber bolts in the bottom will not be a good idea. Just run the stock bolts bottom, smaller up top. I've been doing that and hitting corners at 30MPH+ with streets that have potholes (chewing my winter tires up lol) and have had no issues at all with it slipping out. The shop I had it aligned at did the bolts... I guess it's what they do lol.
post Dec 23, 2011 - 10:56 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Thanks rabid. I might put it in for an alignment after Xmas and see how it goes.
In the meantime, this is how i'm rolling:
Because..
I'm waiting on these bad boys to dry:
This post has been edited by Timmyface: Dec 23, 2011 - 10:57 PM
post Dec 24, 2011 - 3:08 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Came out alright i guesssss haha.
post Dec 24, 2011 - 4:36 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
spray paint I'm assuming. with the black rims it doesn't make it look as flush as before. the silver made it look like it was more flush with the fender and quarter panel. you should of invested in some plasti dip spray paint (that way you could of taken it off like a sticker, if you didn't like the black color).
post Dec 24, 2011 - 5:09 AM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
QUOTE (BonzaiCelica @ Dec 24, 2011 - 4:36 AM) *
timmy your car is full of win, thats why your in my sig and the rims look pretty sweet black (although i might be biased to black rims on red cars haha)
post Dec 24, 2011 - 6:34 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Yeah i know, im still pretty unhappy with my rear wheels, but i guess a change is good.
I have a rim sticker coming so i have a silver lip, so that may compliment it a bit and make it look a bit more flush maybe haha.
It was my first time doing it... came out pretty rough. Could probably have used a few more layers, or good layers at that. I was unsure if i was applying it to light or too heavy.
post Dec 24, 2011 - 9:02 AM
These, perchance? I'm eager to try a set. Ebay wheel sticker
post Dec 24, 2011 - 3:12 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Exacct ones haha. But, comic from USA to aus in Xmas time, don't know when ill get them.
post Feb 18, 2012 - 8:00 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
post Feb 19, 2012 - 11:58 AM
richee3
Joined Jun 29, '08
From Denver
What the.... What happened? And please tell me they didn't damage the splitters when they loaded it up.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 19, 2012 - 4:31 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
No idea what happened, car just died on me and wouldn't start.
The tow guy was a nice one luckily, got planks of wood to get it up, with say 3mm clearance of ripping it off lol.
So far, I'm replacing the distribute cap and coil today, see how it goes.
post Feb 23, 2012 - 4:59 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
^ Turns out it was my Ignition Coil that sh*t itself. So i replaced that, the dizzy cap and rotor button. Running all good now!!
Meanwhile,
I redone my boot again, in material this time. Really happy with it, ill post another photo soon.
This post has been edited by Timmyface: Feb 23, 2012 - 4:59 AM
Lo-Fi Version Time is now: November 29th, 2024 - 10:55 PM
