> Need help finding ST205 maintenance part numbers
post Feb 3, 2011 - 7:53 PM
TEAMFaint
Joined Nov 4, '06
From Medicine Hat, AB
Time to do a refreshing on the car since its at its 96,000 kms maintenance.
I am needing to find some part numbers for the following:
OEM spark plug wires (or any other recommendations for wires)
OEM Cap
OEM Rotor
OEM Fuel Filter
Going to be going with Copper Spark Plugs and cleaning of the injectors.
Also any other recommendations would be great to what else I should be doing.
Also, I found this site, just need to find out what parts I`m actually needing. Sounds noob I know.
But im assuming the Coil Assy, Ignition is the plugs I am needing?
http://www.toyodiy.com/parts/p_J_1994_TOYO...BLMVZ_1901.html
Need confirmation of proper parts #.
19101 CAP SUB-ASSY, DISTRIBUTOR
19101‑88460 3SG*..ST202, 205 1 $50.23
19102 ROTOR SUB-ASSY, DISTRIBUTOR
19102‑74040 3SG*..ST202, 205 1 $10.18
3300P FILTER, FUEL (FOR EFI)
23300‑79425 3SFE, 3SG*..ST20* 1 $35.67
Sub-assembly is what I am looking for correct?
This post has been edited by TEAMFaint: Feb 3, 2011 - 8:04 PM
current project: looking :(
Lo-Fi Version Time is now: December 2nd, 2024 - 3:52 AM
