7a and 4a flywheel.... are they the same? |
Feb 8, 2011 - 4:38 AM |
Enthusiast Joined Jan 21, '11 From UK Currently Offline Reputation: 0 (0%) |
I'm trying to replace my clutch with a better one, somewhere in the 300ft/lbs capacity. Does anybody know if a clutch for the 4a fly will bolt up to the 7a fly without problems? Cheers in advance.
Feb 8, 2011 - 9:21 AM |
i really dont know, the 1ZZ and 2ZZ clutches are interchangeable, just not the flywheels. and the 5S-FE and 3S-GTE could use the same flywheel with some minor touch ups. toyota has alot of similarities and then they throw in a difference to mess ya up. i think i just posted a bunch of un-helpful information
Feb 8, 2011 - 12:52 PM |
Enthusiast Joined Jan 13, '11 From Newnan, GA Currently Offline Reputation: 1 (100%) |
7A and 4A both use 212mm 6 bolt flywheels. The 1ZZ also uses the same flywheel.
The 2ZZ uses an 8 bolt. My experience in this is from owning a 4AGE20V and wanting a new flywheel when I replaced my clutch. Parts stores carried the 8-bolt, but no 6-bolt flywheels. |
Feb 8, 2011 - 12:58 PM |
no i can tell you 100% that the 1ZZ uses an 8 bolt flywheel
Lo-Fi Version | Time is now: January 10th, 2025 - 12:22 AM |
