![]() Enthusiast ![]() ![]() Joined Nov 4, '06 From Medicine Hat, AB Currently Offline Reputation: 2 (100%) ![]() |
Anyone help a guy out?
Overhauling the 205 maintenance wise to try and convince myself to keep the thing. ![]() also need part number for the water level sensor for the w/a intercooler. -------------------- current project: looking :(
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
89465 SENSOR, OXYGEN
89465-29725 ST205 1 $224.39 89256 SENSOR, LEVEL WARNING 89256-20010 ST205 1 $121.05 From ToyoDIY ST205 (Switch & Relay page 1,2). ![]() -------------------- |
ahh couldnt find em! dangit thats a pricy o2 sensor
![]() & of course, now to find one... -------------------- current project: looking :(
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
are u getting code 54? i just cut the wires and joined them together, it's a pain in the ass that water level sensor.
-------------------- Mike W
are u getting code 54? i just cut the wires and joined them together, it's a pain in the ass that water level sensor. Yes I am getting code 54. Can you help explain what you mean by cutting the wires and joining them together? I have checked my pump. Works fine. Fluid is topped up. I wanna get rid of this code. I know there is a black and red wire off the sensor. How do I "join these" to the other end of the plug. Do you mean cut the black and red wire and simply splice them together and then attach it to the other end of the plug in the engine bay? -------------------- current project: looking :(
are u getting code 54? i just cut the wires and joined them together, it's a pain in the ass that water level sensor. Yes I am getting code 54. Can you help explain what you mean by cutting the wires and joining them together? I have checked my pump. Works fine. Fluid is topped up. I wanna get rid of this code. I know there is a black and red wire off the sensor. How do I "join these" to the other end of the plug. Do you mean cut the black and red wire and simply splice them together and then attach it to the other end of the plug in the engine bay? for the o2 sensor you can order one for a 93 alltrac, they are the same. for the level sensor, just unplug it, cut the plug off the harness side, and bridge the 2 wires together. then you can remove the little boot covering the wiring going to the sensor itself, and snip the wires off, and reinstall the little boot for a clean look. -------------------- Former Team 5SFTE pro member ;)
Thanks for the info my friend, will be tackling this today! This post has been edited by TEAMFaint: Feb 10, 2011 - 12:54 PM -------------------- current project: looking :(
Lo-Fi Version | Time is now: February 21st, 2025 - 12:18 PM |
