> Steering wheel movement on bumpy roads, normal or does something need replaced?
post Feb 10, 2011 - 9:05 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
My car handles pretty well on smooth roads, but when I get on roads with imperfections or bumps, my steering wheel has a tendency to jolt around left to right according to the bump. My prev vehicle was RWD so this never really occurred. Is this normal for a FWD car or is something loose/in need of replacement?
Thanks.
post Feb 10, 2011 - 9:06 PM
mkernz22
Joined May 10, '10
From MA
mine does it all the time, it shouldn't be a big deal
post Feb 10, 2011 - 9:37 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Same here. Power steering isn't super tight.
June '12 COTM
'95 AT200
post Feb 10, 2011 - 11:04 PM
chacha
Joined Dec 29, '05
From So-Cal
i would say, if the car is old, which ours are...replace the steering rack pinion, check for other steering replacement...endlinks, anything with the suspension and made out of rubber...see if it is torn...engine mounts
This post has been edited by chacha: Feb 11, 2011 - 1:20 AM
post Feb 10, 2011 - 11:24 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
What other things will need replaced in the suspension/steering?
This car is relatively new to me so I still haven't figured out the suspension set up etc.
Anyone have diagrams or anything? Should I replace sway bar endlinks etc?
post Feb 10, 2011 - 11:31 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Mycurse180 @ Feb 10, 2011 - 10:24 PM) *
It wouldn't hurt to replace endlinks, IIRC, they aren't connected to the steering assembly, so they wouldn't be the cause.
June '12 COTM
'95 AT200
post Feb 10, 2011 - 11:34 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
It sounds like you are describing some worn struts. New struts always seem to help that "bouncing all over the road" feel. I'd say you probably are in need of struts badly if it is causing that.
Side note: When I installed new axles, I noticed the steering became very much "tighter" than it was previously. Also more sensitive, felt like a new car.
I wouldn't go replacing things like crazy though. The cars are old, as chacha mentioned before, and things are getting loose and worn.
Edit: Try the bounce test.
This post has been edited by samir0189: Feb 10, 2011 - 11:41 PM
My F/S Thread!
Ferdi says (11:29)
post Feb 11, 2011 - 1:25 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
what do u feel when u put fancy end links?
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: January 10th, 2025 - 8:54 AM
