installation of cartridges, the cap... |
Dec 3, 2003 - 12:37 PM |
Enthusiast Joined Aug 14, '03 From atlanta ga Currently Offline Reputation: 0 (0%) |
my question is
for the front struts. what did you use to cut the cap on the housing to remove the cartridge and did you weld the cap back on or what? thanks |
Dec 3, 2003 - 1:55 PM |
Mine actually twisted off once we used enough pressure, and then twisted back on without problems from what I remember.
Dec 3, 2003 - 3:11 PM |
Enthusiast Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
Check this link out, they show how they cut the housing apart.
Don't know what the exact name of the tool they used, but someone told me that it's similar to what plumbers cut piping with. Hope that helps. http://www.y8s.com/celica/suspension.html |
Dec 3, 2003 - 6:25 PM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
yup, mine were on REALLY tight. I had torch the cap before it came off. good thing the koni's came with replacement caps. |
just put you sturts on a table clamp and use a monkey wrench to twist the tops off
Dec 3, 2003 - 7:41 PM |
Enthusiast Joined Jul 5, '03 From Scotland , Uk Currently Offline Reputation: 0 (0%) |
as macavely sayed , i did the exact same thing about 2 weeks ago ..
Kevstir -------------------- |
Dec 3, 2003 - 7:53 PM |
right on, thanks
Lo-Fi Version | Time is now: January 19th, 2025 - 10:17 AM |
