> Turbo timer question
post Feb 13, 2011 - 5:50 PM
fran
Joined Apr 28, '07
From Venezuela
hello! i just finish to install my greddy turbo time on my celi!... I follow carefully all the intruccion!. but got problem with the instalation!.. When i put in off the swicth the turbo timer starts is countdown, thats fine, but all the function of the cars dosnt work! like the cooling system and the handbrake safety do not work too :S the speed sensor that comes with the timer dont function and the secure doors lock open when the car its finish is countdown and turn off :S anyone have install these timers? a little help will be apreciated!
Thanks 6gc friends
Fran
post Feb 13, 2011 - 6:58 PM
Neon90424
Joined Jan 19, '11
Aren't turbo timers made to ONLY work when the hand brake is on?
post Feb 13, 2011 - 8:55 PM
fran
Joined Apr 28, '07
From Venezuela
Yup, but when i pass the switch to off the brake ligth in the dash turn off, so if i quit the hamd brake the car dont turn off :s... The air conditioning system dont work and the cooling system dosnt work! so i guess that if i let the car running with the turbo timer 3min for cooling down the turbo he can get a re-heat :S
post Feb 14, 2011 - 6:06 PM
Matthew101
Joined Feb 14, '11
check your wiring or check your turbo timer
post Feb 14, 2011 - 6:16 PM
Matthew101
Joined Feb 14, '11
can i have the turbo timer wiring diagram because i want to put a turbo timer in my car plzzzz biggrin.gif
post Apr 24, 2011 - 10:54 PM
fran
Joined Apr 28, '07
From Venezuela
i check all the wiring! and its ok!... I dont know if i must put the on switch into another calbe, because when i get the key to off and remove the key the countdown starts but the cooling system do not work when the switch its off! so if i left the car over 5 min without the cooling system working im shure that the car will over heat!... Anyone know anything about this problem?
post Apr 25, 2011 - 1:41 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
nothing is supposed to work when its in countdown.
i really dont understand what else you're trying to say but,
the only things that need to be active are fuel and ignition when in countdown mode.
i dont understand what you mean by the doorlocks open when the countdown is finished, i think thats f*cked up
my fan never runs in countdown either
Mike W
269awhp / 273ft-lbs
post Apr 25, 2011 - 2:31 PM
Culpable04
Joined Apr 17, '06
From New Jersey
if he has an aftermarket alarm system, it may explain why the doors unlock when the countdown ends. Most alarm systems will unlock the doors as soon as you turn the car off and lock them when you turn the car on.
everything else sounds normal.
post Apr 27, 2012 - 6:36 PM
fran
Joined Apr 28, '07
From Venezuela
problem solved... the issue was that the acc cable was wrong connected... must be conect to the blue wire, so blue for acc in the greddy turbo timer to blue in the switch car, then green to ON cable that is the black on the switch and the red to constant 12v that is black and red in the switch. With these cable conected the fan will work without the switch key... Now ill be working on the lock issue that happends when the car turn off the doors go to unlock
Lo-Fi Version Time is now: November 23rd, 2024 - 12:11 PM
