> creaking upon acceleration., Coming from passenger side I think!?
post Feb 16, 2011 - 2:42 PM
_john_
Joined Feb 16, '11
From London
Hi
Upon accelerating, or being at low revs in first and second; there is a creaking/groaning sound coming from the central/passenger side of the car (left hand side)
I've searched through the forums but there doesn't seem to be much that's exactly like this, I did a test by pushing down on the suspension and there was no noise, it's only when I'm releasing the clutch in first and second.
Any advice or help would be amazing
John
post Feb 16, 2011 - 2:57 PM
simondejazmach
Joined Feb 15, '11
From Hollywood
Hmm.... sounds a bit weird, but as u said if it disappeared after u played with the suspension, i guess u found the problem already. Just try to take a good look at it and find if there`s anything broken or so.
This post has been edited by simondejazmach: Feb 16, 2011 - 2:57 PM
post Feb 16, 2011 - 3:00 PM
_john_
Joined Feb 16, '11
From London
I didn't change the suspension, I just pushed down on the front wing/fender (whatever you wanna call it!) and there was no noise apparent, it's only happening when I'm dropping the clutch out frown.gif
post Feb 16, 2011 - 5:25 PM
Black-ST202
Joined Mar 1, '09
From Norway
Hiya John. What type off car it that you have? Suspension's? I did a quick search off the web and found this ( http://priuschat.com/forums/gen-ii-prius-c...ion-06-a-3.html ) I know my borther had a problem on his 200sx. But that was an old support bushing that was worn out in the front. Could not hear it when the car was standing still. Only when driving the car the sound could be detected.
Maby you should take a look at the left side and see if you find anything there.
post Feb 16, 2011 - 10:02 PM
Check the tightness of the strut bolts.
post Feb 17, 2011 - 3:28 AM
playboymma
Joined Jan 7, '11
From Mena, AR
mine makes kind of a creaking/groaning sound on the passenger side and when i pulled it apart i found that the wheel hub was completely worn out. try checking your wheel hub. if you dont know what to look for, pm me and ill be glad to help you out
I went full retard once, too. Its OK.
post Feb 17, 2011 - 7:58 PM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Sounds clutch related, does it happen in gear when you don't have your foot near the clutch?
My mums car just got the clutch done and it makes a few weird noises when you are at the friction point, sometimes they make a bit of noise, especially when they are new.
post Feb 18, 2011 - 1:58 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
is it a rotational noise or a one off noise?
examples of rotational noise - wheels toe-in misaligned, shot wheelbearings
or one off noise like suspension knock from a broken ball joint, engine knock from busted front/rear engine mount bushes
Mike W
269awhp / 273ft-lbs
post Feb 27, 2011 - 10:22 AM
mkernz22
Joined May 10, '10
From MA
so this just started happening with my car. whenever i turn, my passenger side makes a creaking sound. i thought it might just be the spring moving, but i'm guessing from the post above that its the wheel bearing? it doesn't do it all the time, just when im turning at slow speeds (and not all the time either)
Lo-Fi Version Time is now: April 21st, 2025 - 2:50 AM
