How to replace window weather strip? |
Feb 19, 2011 - 4:15 PM |
Enthusiast Joined Apr 8, '03 From New York City Currently Offline Reputation: 0 (0%) |
I need to replace the inside front window weather strip, the one that runs along the top of the door. Do I need to remove the interior door panel? Thanks.
Feb 20, 2011 - 12:34 AM |
Enthusiast Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
I think that is actually a part of your interior door panel
Feb 20, 2011 - 6:58 AM |
Enthusiast Joined Aug 15, '10 From UK Currently Offline Reputation: 0 (0%) |
Hi there...when I re-sprayed my Celica you can remove it from the door.
Best way I found to remove it is wind your window down all the way, shine a torch down the window channel. You should see some blue clips that hold the weather strip in place. It may need a little persuasion to unclip but once the first one it down, the rest will follow. |
Feb 21, 2011 - 12:00 AM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
I need to replace the inside front window weather strip, the one that runs along the top of the door. Do I need to remove the interior door panel? Thanks. Yes, to remove the inside weather strip you need to remove the door panel, because they are attached to the door panel itself. Luckily, they are rather easy to remove. -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:20 AM |
