> 3s-gte overheating
post Feb 21, 2011 - 1:41 AM
ryancmcinnis
Joined Aug 9, '08
From san diego
Hey, I have a problem with the 3s-gte in my celica. I did the swap from the 2.2 a few years ago and it ran fine for a few years. Recently it overheats with I get on the highway. I've tried alot of the basic stuff so far, but no luck. Changed the thermostat, did an engine flush, and I threw on the radiator and fan assembly I had leftover from the swap. Seems to be a flow issue, but cant figure it out. The engine temp will shoot up and the heater cools down and when I downshift, the temp drops followed by hot air from the heater. The system has pressure, and the radiator cap is good. All the hoses seem to be in good order, and when I did the flush everything that came out looked clean. Any ideas?
post Feb 21, 2011 - 5:56 AM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
did you bleed out the system when you did coolant? might be air bubbles in the system
post Feb 21, 2011 - 1:49 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
its a long shot, but maybe the water pump is not pushing well enough. try changing that. do you hear a water sound in the heater core whe you step on the gas.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 21, 2011 - 8:02 PM
ryancmcinnis
Joined Aug 9, '08
From san diego
QUOTE (team_omega @ Feb 21, 2011 - 6:56 AM) *
ya i did
QUOTE (Smaay @ Feb 21, 2011 - 2:49 PM) *
i'm not too sure, wasn't listening for that though. I'll check that out, see if hear anything. Any reason the water pump wouldn't push water well enough?
post Feb 21, 2011 - 9:13 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
50/50 mix of water/antifreeze (depending on your region) or it could be the thermostat is stuck/broke.
post Feb 24, 2011 - 1:03 AM
Araykhel
Joined Sep 21, '10
From Woodstock, MD
Just got done figuring my overheating issue, the waterpump is a great thing to check.
post Feb 24, 2011 - 2:13 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
How do you "bleed" the cooling system?
Everything will come out if you try to fill it with the thermostat off and the only way to get past the thermostat is with a hot engine, and working on the cooling system when its hot is just crazy.
Mike W
269awhp / 273ft-lbs
post Feb 24, 2011 - 2:31 AM
cjh4l22
Joined Oct 18, '06
From cincinnati
even with a t-stat closed the system is a cycle so its gotta go to the other side of the tstat somehow... you can rent a pressure building tool that will force it into the system. and move all the bubbles out
post Feb 24, 2011 - 2:50 AM
delusionz
Joined Feb 11, '08
what about idling the car up to temperature with the rad cap off and topping up as necessary? thats what ive done after system flushes in the past
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: January 10th, 2025 - 9:20 AM
