> steering problemish, small problem just wondering
post Feb 21, 2011 - 4:09 AM
dariodudes
Joined Oct 16, '10
From Vancouver
Ok so i had a quick question, when my engine is cold, and i make a full turn, i hear a shuddering sound and i feel it in my steering wheel.
But the funny thing is when my car is warmed up no sound whatsoever. now, there's a slight leak in my rack and pinion, so that might be it, but my mechanic friend seems to think that my power steering belt might be on too tight which might explain why it only happens when its cold.
so thats my conundrum.
any explanations?
any help would be greatly appreciated
thanks
post Feb 21, 2011 - 9:00 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Yup, that's probably it. I think my belt is on too tight and when my engine is cold, it whines when I turn the wheel. (Only when it's below 65 degrees or so outside, it never does it in the summer). and I have no leaks in my rack & pinion.
I just attribute it to rubber being hard and compressing when it's cold. So when it warms up and expands, it grips better and the whine goes away. I might be wrong, but that's been my logic for a while.
This post has been edited by HectortheRican: Feb 21, 2011 - 9:01 AM
June '12 COTM
'95 AT200
post Feb 21, 2011 - 10:32 AM
rave2n
Joined May 29, '09
From Gainesville, FL
Mine was making quite the noise for some time.
After changing out the steering pump, belts and pulley. I learned that it was simply not tight enough, even through all my means to tighten it via the steering pump bracket.
I missed the adjustment bolt under the altenator. Few turns on that, removed the noise. Check it out, might be your issue, considering they share that belt on the 7AFE.
post Feb 21, 2011 - 12:26 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Get new belts and tighten it up better
2001 Solar yellow Lexus IS300
post Feb 21, 2011 - 1:46 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (96stgreendemon @ Feb 21, 2011 - 1:26 PM) *
Make sure your resivour is full because as it gets dirty it looks like full to the line but really isn't.
post Feb 21, 2011 - 1:56 PM
HectortheRican
Joined Dec 26, '09
QUOTE (xrav22 @ Feb 21, 2011 - 12:46 PM) *
I hate to thread jack.. but every time I attempt to check the PS reservoir, I can't even tell.
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: December 4th, 2024 - 6:45 PM
