> Fuel Pressure Regulator... do I need one and how to install.
post Feb 22, 2011 - 8:48 PM
czwalga
Joined Sep 27, '10
From pittsburgh
My question is how reliable is the stock fpr with aftermarket fuel pumps. I'm running an external pump with my fuel cell.
If I do install an aftermarket one, probably aeromotive, do you just take the stock fpr off the fuel rail and cut out the internals or something, it's a unique setup with the fuel rail. So you almost need the fpr on there just to hook up the return to the tank.
This post has been edited by czwalga: Feb 22, 2011 - 8:57 PM
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Feb 23, 2011 - 12:32 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
no you figure out the thread of the stock FPR and put in a AN fitting and run a -4 line to the FPR. then out the regulator back to the tank
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 23, 2011 - 6:48 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (Smaay @ Feb 23, 2011 - 12:32 AM) *
I guess I didnt take the fpr off the fuel rail, but i just took a quick look yesterday and it looked like it was held on by two bolts, not a thread. I could be wrong; i'll have to take it apart tonight.
-10 F150
post Feb 23, 2011 - 7:26 AM
czwalga
Joined Sep 27, '10
From pittsburgh
Not a thread... like I thought. I really don't want to go through the trouble, I can't weld cast aluminum with accuracy, just tacks and stuff. I think i'm going to try and just use the stock regulator and see how that goes.
Welded on a bung.
-10 F150
post Feb 23, 2011 - 10:02 AM
i used the walboro 255 pump for 5 years with the stock regulator on my 5sfte.
you should be fine.
post Feb 23, 2011 - 11:29 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (presure2 @ Feb 23, 2011 - 11:02 AM) *
you should be fine.
Thanks.... that's pretty much the answer I was looking for. Wasn't sure if the higher volume pump would where the stock regulator out somehow.
-10 F150
Lo-Fi Version Time is now: January 10th, 2025 - 2:00 PM
