![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) ![]() |
hey guys, does anyone know the inner size of the main vacuum lines on the 5s, the ones on top of the intake. and how do you remove the pcv valve on the head.. do you just pull it out?
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
3mm, 5mm, 8mm & 10mm
-------------------- Mike W
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
the PCV should just pull out but if its old and hard it might break. i had to break the rubber gromet it sits in to get mine out.
thanks guys!
Lo-Fi Version | Time is now: April 23rd, 2025 - 12:17 AM |
