Enthusiast ![]() ![]() ![]() Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) ![]() |
Can somebody tell me how the outside pad is supposed to be sloted?
I can't remember if the brass thingie on the pad is supposed to be like this or mirrored? ![]() Or does it actually matter? Thanks! -------------------- ![]() |
Its the same as the inside pad.
Its the same as the inside pad. Inside pad does not have it, only outsides. Anybody? -------------------- ![]() |
![]() Enthusiast ![]() ![]() Joined Oct 25, '07 From Eagan, MN Currently Offline Reputation: 3 (100%) ![]() |
Theoretically both sides should have the tab. But I've also had it where only one has the mounted tab. Put the tabbed one on the outside and the regular one against the piston. Honestly it doesn't really matter. Its all about ease of fitment for install. Hope that helps
-------------------- -Tyler
That's what I thought: the inside ones (against piston) had no tabs at all and the outside ones had only one tab...
Lo-Fi Version | Time is now: April 21st, 2025 - 4:45 AM |
