> "Please help" TRD side skirts and corners, Help me with the side skirts reference
post Mar 1, 2011 - 11:50 AM
Rubentxo
Joined Sep 19, '04
From Spain
Hello.
I would like to know the number of pieces of the TRD kit.
I'm talking about the side skirts and front and rear corners.
Currently, I carry in my car and are original. In my country cars must pass a technical inspection every year and by law you may have to justify this type of piece.
I found the numbering of the side skirts of st205 and others, but I'd like to know these pieces.
There is some database like toyoDIY where it appears printed image?
These enumerations could be?
Stock sideskirts - These Were an option on American and Japanese 96-99 Celicas. They will fit and Stock Celica hatchback coupe or Without modication. Parts Can Be Any dealership or ordered from discounted Often found at a Used parts distributor (Thanks to the Following CelicaQT for part numbers).
(1) 76911-20900 Mudguard, Side R (This is the skirt Itself)
(1) 76912-20900 Mudguard, Side L (This is the skirt Itself)
(2) 76925-20020 Protector, Side M (Rubber seal) Make sure you tell Them What color. There's a color code Specify They When you order it.
(1) 76927-20040 Protector, Side M (Goes Between the inside of the skirt and the sheetmetal)
(1) 76928-20040 Protector, Side M (Same as above discription only it's a small piece)
These Are the fasteners:
(4) 90159-60414 Screw, W / washer
(8) 90159-60420 Screw, W / washer
(4) 90189-06006 Grommet, Screw
(8) 90189-06154 Grommet, Screw
(16) 90467-09185 Clip
(18) 90467-10162 Clip
Thank you all.
I hope you can help me.
This post has been edited by Rubentxo: Mar 2, 2011 - 3:01 PM
post Mar 2, 2011 - 2:38 PM
Tom_SS2
Joined Jun 12, '09
From Hull, England
they are not officially TRD bits of kit but everyone seems to refer to them that way, they are Toyota optional/dealer extras. they differ from the 96-99 skirts as they are larger/drop lower. sorry i can't be any more help then that.
add a "please help" to the thread title it may get more views.
post Mar 2, 2011 - 2:55 PM
Rubentxo
Joined Sep 19, '04
From Spain
Sorry. I'm not very familiar with the forum.
If Toyota are optional, they could give me the references in the toyota dealer? Still being plastic, I must admit that they are of a plastic as thick as normal st205.
Sorry for my English. I hope you get me.
Thanks for answering.
post Mar 2, 2011 - 11:20 PM
chacha
Joined Dec 29, '05
From So-Cal
im sure there is a number reference, but im just afraid because they are optional extra, toyota themselves might have it under "discontinued" and no longer provide the part number.... best thing is to find someone who works in Japan Toyota Warehouse to look at the secretive toyota data base part number and verify the numbers correctly. even some USA toyota dealership don't have the data base part number for the ST205 and let alone very few big toyota dealership do.
Good luck, the Toyota optional side skirts (TRD) will definitely be a nice info to add on along with the front and rear spats.
post Mar 3, 2011 - 7:03 AM
Rubentxo
Joined Sep 19, '04
From Spain
I have two images of a catalog in which they appear celica placed on the limited edition TOM'S celica with an additive instead of the front corners.
I'm afraid I will not get the reference numbers. In the piece itself but perhaps they should come letters engraved on the plastic are not, because I look in your day.
Lo-Fi Version Time is now: November 23rd, 2024 - 4:13 AM
