Mar 2, 2011 - 7:18 PM
Enthusiast Joined Nov 1, '10 From uk Currently Offline Reputation: 0 (0%) |
i fitted new fuel pump n now it wont start it trys but just gettin loads white smoke which if remeber rite is over fuelin or is it ? also does the fuel system need bleedin after fittin new fuel pump because of drainin the system so was thinkin maybe air in there and could it be my fuel pressure regulator as not workin as it a fse boost valve n dont think much to um anyways do u think better off installin the standard pressure reg
thanks |
Mar 2, 2011 - 7:29 PM
you might have some air in teh system, but since its a return style is should work its way back to the tank fairly quickly, black smoke is from too much fuel, white smoke is usually coolant in the system, or just water like condensation
Mar 3, 2011 - 8:26 AM
you might have some air in teh system, but since its a return style is should work its way back to the tank fairly quickly, black smoke is from too much fuel, white smoke is usually coolant in the system, or just water like condensation k sound i got it to run but it just dies as soon as try to drive it ive allways had trouble with it like when i go up hills it just looses all power n was told i was fuel pump givin out losein pressure so ive changed that n now it doin this lol but thinkin couid it be fse boost valve stuffed thinkin changin that back to standard but if u say is rite u thinkin haed may have gone will have to presssure test it thanks for input man cheers |
| Lo-Fi Version | Time is now: August 25th, 2026 - 11:23 AM |
