Engine Flush, Any info on this is appreciated |
Mar 7, 2011 - 11:02 AM |
Enthusiast Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
My Dad and I were talking about ways to clean my engine internally without completly tearing it down. He told me a great, easy, and inexpensive way to do this, is run karosene thru it as it idles. Apparently it cleans and and restores your pistons, cylinder walls and valves by cut through the carbon and old burnt oil that develope over time. He told me that during the cleaning process my car will smoke bad but only for a few minutes due to all of the dirt and carbon build up. That once the process is done and fresh new oil and filter have been replaced, and installed, the motor will be good to go. Does anyone have any expierence or knowledge of this and have you noticed any sort of power gain that may have been lost over time? -------------------- From Japan to Texas my st202 follows me.
Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Mar 7, 2011 - 11:16 AM |
Enthusiast Joined Mar 20, '10 From uk, essex Currently Offline Reputation: 0 (0%) |
The company ecotek do a foam called the power boost
Engine enigizer, you warm car uP, pull the Pcv pipe rev Car to 2000rpm and spray it in, cleans The hole engine though the heat. Car will smoke like mad but it's all the crap coming out the motor, good stuff or ammate of mine rekons a drop of redex in each bore and start it but it sounds a boge to me, might stil work though |
Mar 7, 2011 - 11:37 AM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Seafoam does this too.
June '12 COTM '95 AT200 |
Mar 7, 2011 - 1:34 PM |
Enthusiast Joined Dec 23, '10 From PA, USA Currently Offline Reputation: 0 (0%) |
It will smoke some crud out but it will not "repair" your engine at all. |
Mar 7, 2011 - 1:44 PM |
Not looking to repair, because there is nothing wrong with it, lol. Just want to make sure everything is clean before I drop it back in for the time being. Im very high maintenance when it comes to the cleanliness of my car.
Mar 7, 2011 - 4:14 PM |
Just throwing it out there. Many people I know use Seafoam with good results. |
Mar 7, 2011 - 4:18 PM |
I been hearing alot about seafoam, even seen advertisements on O'Reilly boards, is it really that good?
Mar 7, 2011 - 4:23 PM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
Yeah. You can use it to clean your fuel systems, intake, and oil systems. You already mentioned you were changing your oil and filter after too. It is recommended you change it around 200 miles after you seafoam your oil. I've personally only used it to clean out my intake, you just spray it in a vacuum line, lots of smoke, then its clean.
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Mar 7, 2011 - 4:25 PM |
Thanks for the info, deff. gonna have to keep that in mind. -------------------- From Japan to Texas my st202 follows me.
Mar 7, 2011 - 5:48 PM |
seafoam FTW.
13.6@108MPH, 5SFTE Powered |
Mar 7, 2011 - 5:51 PM |
Enthusiast Joined Oct 7, '09 Currently Offline Reputation: 8 (65%) |
i can see this being very true, because a couple years ago i remember my dad got a car where the engine internals wouldn't even move because he bought a car from a lady who had the car 97k miles and never changed the oil once, he emptied out what he could of the oil, and poured in kero let it sit for 2 days, emptied it back out and put straight kero back in, did what you said about starting it and letting it run for about 5 minutes, then emptied it back out and did an oil change and it ran like a top again.
so i'd have to agree with you that it would clean everything very nicely inside -------------------- NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold 1997 Celica ST- swapped and sold 2004 Ford explorer xlt 4x4- totaled 1997 Celica Convertible GT- Going Topless (; (18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi ( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 ) |
Mar 11, 2011 - 2:53 PM |
Enthusiast Joined Feb 15, '11 From Hollywood Currently Offline Reputation: 0 (0%) |
Yup, i just did it about a month ago before going synthetic on my baby.
All i did was pour the engine flush and run it for 5-7 min. and change the oil. I dont think its of any risk. Um not sure but u can also seafoam it, but dont take my word for it, RESEARCH! |
Lo-Fi Version | Time is now: January 10th, 2025 - 10:59 PM |
