> Clutch, shifting problems
post Mar 8, 2011 - 7:50 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
Alright i need some help the other day out of no where i was driving shifting into 3rd it went in a little rough it felt funny. I payed no mind because 3rd has always went in a little rough, well as I try to go into 4th it wont let me, the tranny was stuck in gear and i had to force it out. It felt like my clutch wasnt disengaging when i push the clutch in. So i finally made it home forcing every gear in and out. So my first thought is slave cylinder or master cylinder. So I check them, not leaking and seem to be working fine the rod on the slave cylinder is pushing out and holding the fork very firmly and i have pressure in the pedal.
But it does feel like the pedal is low at a stand still if i try to leave out of 1st the clutch engages very low.
Has anyone had a similar problem and fixed it?
post Mar 8, 2011 - 8:11 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
get those symptoms when your mc is due for a rebuild. if you have to drive like that, sometimes you can get it to play ball by sticking your toes under the pedal and prying it back out as far as it can go and then giving it another go pressing it to the floor.
you could try bleeding it and refilling it incase its just some air bubbles
Mike W
269awhp / 273ft-lbs
post Mar 8, 2011 - 8:58 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Sounds like air in the line, try bleeding before cracking her open.
post Mar 8, 2011 - 10:04 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
Yeah i tried that i bled the system all new fluid still feels the same, I was thinking the it was the MC i was just doubting that cuz i have pressure in the system and the pedal returns on its own but i did notice that the rod from the MC was adjusted all the way out on the pedal. I guess ill have to order a new MC and see if thatll work. thanks
Lo-Fi Version Time is now: November 22nd, 2024 - 9:07 PM
