> Anyone has the HKS Type 1 Turbo timer, Wanna kno if this is good
post Mar 11, 2011 - 7:30 AM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
I'm considering buying a turbo timer, am actually thinking about buying the HKS Type one, because of the digital tach and speedo. Does anyone have this installed and use all the features?
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post Mar 11, 2011 - 8:59 AM
BriinumsBo
Joined Feb 6, '08
From Latvia
had it on my st185 (check http://www.turbocelica.lv ) i had the previous generation (ugly looking)
awesome unit by all means and highly recommend over the type-0 ! other brands dont come even close unless the function is included in aftermarket ECU..
go ahead and buy it. also get the harness which makes it 2x ieasier to set up, but if u cant get it, dont worry, its not hard to wire it up =) i received wrong adapter, the seller offered to exchange it for the correct version, but i didnt bother as it took me just 30 mins to figure out which wires to splice/connect..
This post has been edited by BriinumsBo: Mar 11, 2011 - 9:00 AM
1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ
post Mar 11, 2011 - 9:08 AM
cax_11
Joined Aug 15, '10
QUOTE (BriinumsBo @ Mar 11, 2011 - 9:59 AM) *
Nice!! smile.gif So do you use the RPM and Speedo functions? Which wire does the speedo Connection hook up to?
Nevis, West Indies
post Mar 11, 2011 - 3:23 PM
orlando_gt4
Joined Mar 3, '11
From Dublin
Hi
I have it in my ST205 and yes you see RPM, Speed in KM, Has a timer aswell so u can record or 0-100km/hr times, obviously timer for turbo, and alot of other different settings that need to be played around with all and all its worth the money. but just to be sure i didnt instal it myself took it to a friends garage.
post Mar 11, 2011 - 3:28 PM
cax_11
Joined Aug 15, '10
QUOTE (orlando_gt4 @ Mar 11, 2011 - 3:23 PM) *
Hi
Cool, I just ordered it. Just need to know which wire on the ecu to splice for the install. kindasad.gif
Nevis, West Indies
post Mar 11, 2011 - 5:52 PM
orlando_gt4
Joined Mar 3, '11
From Dublin
QUOTE (cax_11 @ Mar 11, 2011 - 3:28 PM) *
Hi
Yeah man you see if your not sure dont play around with it just in case, it will come with instructions but i doubt it will make any sense try the install only if your 100% sure...
post Mar 12, 2011 - 12:09 AM
cax_11
Joined Aug 15, '10
QUOTE (orlando_gt4 @ Mar 11, 2011 - 6:52 PM) *
Hi
That leads to my next question, I wonder if anyone on here can tell me which wires to tap into for the RPM and the Speedometer. It easy to splice just gotta know which wires to splice
Nevis, West Indies
post Mar 12, 2011 - 5:39 AM
orlando_gt4
Joined Mar 3, '11
From Dublin
QUOTE (cax_11 @ Mar 12, 2011 - 12:09 AM) *
Hi
not sure if this is any help to you but have a read..http://www.6gc.net/forums/index.php?showtopic=39426
post Mar 13, 2011 - 9:08 AM
cax_11
Joined Aug 15, '10
I have the TT-4 adapter for my car. I found the speed sensor on the ecu pinout chart, but which wire to tap into for the rpm?
Nevis, West Indies
post Mar 13, 2011 - 8:30 PM
TEAMFaint
Joined Nov 4, '06
From Medicine Hat, AB
Look for "Tach" wire. May not be labelled "RPM".
current project: looking :(
post Mar 13, 2011 - 8:50 PM
cax_11
Joined Aug 15, '10
QUOTE (TEAMFaint @ Mar 13, 2011 - 9:30 PM) *
Here's my ecu pin out, am not seeing the "tach" or "rpm"
Nevis, West Indies
post Mar 13, 2011 - 8:55 PM
TEAMFaint
Joined Nov 4, '06
Well there is another way instead of going to the ecu, run a wire into the engine bay and grab the tach signal from the bay instead of the ECU. Other option if needed.
post Mar 14, 2011 - 12:40 AM
cax_11
Joined Aug 15, '10
OK, I guess I'll have to do that if no one on here can help, I'll post a topic about it and see
Nevis, West Indies
post Mar 14, 2011 - 9:51 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
G1 is the tach signal
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 14, 2011 - 10:11 PM
cax_11
Joined Aug 15, '10
QUOTE (Smaay @ Mar 14, 2011 - 10:51 PM) *
Nevis, West Indies
Lo-Fi Version Time is now: February 16th, 2025 - 10:32 PM
