Closed TopicStart new topic
> Two questions.. 1. about a 5sgte. 2. Will a 2jzge fit?
post Mar 11, 2011 - 9:52 AM
pentathlete5
Joined Dec 25, '10
From Lawrence, Massachusetts
Im wondering if i get a 94-99 5sfe block will it match up to a 86-99 3sge head and will a 91-99 3sgte ecu will fit? of course i know i have to get a turbo but i knew that already. Also im wondering if a 2jzge will fit in a 94-99 celica gt? If it does im wondering what have to be done to do so?
post Mar 11, 2011 - 9:55 AM
mkernz22
Joined May 10, '10
From MA
if you search, you shall find.
post Mar 11, 2011 - 9:56 AM
no, its not a straight bolt on.
NO a 2jz wont "fit"
please read thru the stickys in each forum before posting, and post in the appropriate forum.
post Mar 11, 2011 - 10:18 AM
pentathlete5
Joined Dec 25, '10
no i meant will it fit i know youll have to fabricated some mounts but in the general picture
post Mar 11, 2011 - 10:37 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
NO! What makes you think an inline 6 will fit sideways in the bay?
READ. THE. STICKIES.
**** Photobucket
post Mar 11, 2011 - 10:54 AM
pentathlete5
Joined Dec 25, '10
who said anything bout side ways?
post Mar 11, 2011 - 11:00 AM
mkernz22
Joined May 10, '10
From MA
:facepalm:
you won't be able to fit in it.
95CelicaST
Joined Feb 5, '05
Have you read the stickies yet?
**** Photobucket
post Mar 11, 2011 - 11:03 AM
pentathlete5
Joined Dec 25, '10
no can you send me the thread?
post Mar 11, 2011 - 11:06 AM
Culpable04
Joined Apr 17, '06
From New Jersey
Why The 2JZ-GTE Isn't Feasible
At the behest of Coomer, and myself, I'm writing this sticky so hopefully people will stop asking about this swap. Please read all of this, and if it doesn't answer your questions about this issue, PM me, please don't post on the board, you'll just get flamed, most likely by me. If you read it all and still have questions, PM, don't post!
The question asked: Can I swap a 2JZ-GTE engine (from a 93-98 Supra Twin Turbo) into my 6th Generation Celica?
The answer: Yes, but that's not a good question.
The question that SHOULD be asked instead: Can I swap a 2JZ-GTE engine (from a 93-98 Supra Twin Turbo) into my 6th Generation Celica and STILL KEEP it a Celica.
The answer to this better question: No.
The first question addressed to all of you who take the "with enough money, anything is possible" stance, which is a legitimate one. Yes, you could cut through the firewall, yes you could convert the Celica to rear-wheel-drive, yes, you could do the swap. This is a valid point, but I shudder to guess at how much all this would cost.
Practically speaking, you'd have to buy a complete Twin Turbo Supra to source all the parts you might need (engine, drive-train, and suspension), and if you did that, why not just drive it? You're going to tear apart an amazing car to put the engine in your Celica? What?!!?
Ok, now to address the specifics of why you CAN'T reasonably do this swap:
1) 2JZ-GTE engines are not cheap. You think it's a lot to pay $3,000 for a 3S-GTE clip? A Supra clip will set you back anywhere from $6,000-$10,000. And that's just for the engine. You still have all of the massive custom work, and you need all of the Supra suspension and drive-train, so essentially you need the whole car. If you have 10 grand laying around to put into your Celica, call me, and I will build you the baddest one in the country. There are better ways to spend that money on a 6th Gen Celica.
2) The 2JZ-GTE is an Inline 6 Cylinder engine, mounted longitudinally. The 5S-FE and 7A-FE engines are both 4 cylinders, mounted transversely.
The best way to understand this: open your hood; see how the engine is oriented where the long sides are parallel to the bumper, essentially sideways? The Supra engine is mounted so the long sides are parallel to the fenders. Most rear-wheel-drive sports cars, like the Supra, have their engine mounted longitudinally, whereas front-wheel-drive cars, like the Celica, usually are transverse. This immediately poses the problem of mounting the engine. The Celica engine bay was not meant to ever have a longitudinally mounted engine in it.
3) The 2JZ-GTE is an Inline 6 Cylinder engine. The 7A-FE and 5S-FE are 4 cylinders.
The Supra engine is a LOT bigger that the Celica engines, it is a lot longer. Even if you could overcome the mounting issue (#2) you have the size difference. In order to fit the 2JZ in the Celica bay, you would have to do one of 2 things:
A) Extend the bumper and frame forward about a foot with custom body work, but at the same time destroying the head-on collision safeguards, and also destroying the structural integrity of the Celica frame. Did I mention that this makes the car illegal to drive on the street?
B) Cut into the firewall (the wall between you in the interior and the engine bay), to extend the engine bay to the rear, thus destroying any protection you have against a possible fire (it is called a FIREwall) and again, making the car illegal to drive on the street for a lot of reasons.
At this point I feel I should explain what I mean by "illegal" in the above situations. I'm not talking about emissions/smog, or CARB, or parts meant for "off-road use only." We all know you can get around most of that. I'm talking about "illegal" like the authorities take away the car and don't give it back. You cannot get a car with a cut firewall legally titled in ANY state, no matter who you know, the same for a car with the crash-test safeguards removed. They aren't legally considered cars at this point, just scrap.
4) If those weren't enough to deter you, you still have to convert the Celica to rear-wheel-drive. This is possible, but it will cost a lot of money, and isn't really relevant by this point. If you have come this far successfully, you've paid for at least 2 complete Supra TTs, minimum, probably closer to 3. There are other points I could go into, but by this point, if you aren't insane and Bill Gates, you're out. If not, buy me a Supra! Obviously you have more money than God.
look for STICKIES.
one is here just for you
READ, I mean READ
post Mar 11, 2011 - 12:18 PM
pentathlete5
Joined Dec 25, '10
ok so how bout my 5sgte question?
post Mar 11, 2011 - 12:38 PM
95CelicaST
Joined Feb 5, '05
99 5S block, 3SGTE head, Standalone ECU. I'm not sure what is required for the connecting rods and pistons. SEARCH. Because people have done this. This is DOCUMENTED on this site!
the 99 block doesn't need any machine work to match the 3SGTE head. All 5S blocks pre-1999 will need work to have cooling channels matched up.
Do not use a 3SGE head
Do not use a factory ECU. It will not work. You need a standalone EMS at that point.
**** Photobucket
post Mar 11, 2011 - 1:21 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
this is the same TROLL that posted on NC.org. Posting stupid questions and wasting time
http://newcelica.org/forums/showthread.php?t=329300
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: February 18th, 2025 - 6:45 PM
