> Does anyone know the which is RPM/TACH on the ECU, heeeelppp
post Mar 14, 2011 - 1:14 AM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
its for hooking up a digital rev meter/ tachometer
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post Mar 14, 2011 - 9:55 AM
DGolden32
Joined Apr 28, '09
From Auburn, AL
Not completely sure on the gt-4, but on the 5sfe it is a gray wire and to find it you need to go to the igniter on the rear driver's side of the engine compartment and look in a connector in that area. If you think you've found it, just test it with a multimeter on AC mode
post Mar 14, 2011 - 10:29 AM
cax_11
Joined Aug 15, '10
Ok, will check and see.. thanks
Nevis, West Indies
post Mar 14, 2011 - 11:18 PM
Rusty
Joined Nov 5, '07
From New Zealand
There is a blue plug on the back of the instrument cluster. It is pin # 9, wire is gray.
(found that but will double check)
post Mar 15, 2011 - 2:23 AM
cax_11
Joined Aug 15, '10
QUOTE (Rusty @ Mar 14, 2011 - 11:18 PM) *
would it be safe to splice into that?
Nevis, West Indies
post Mar 15, 2011 - 10:16 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (cax_11 @ Mar 15, 2011 - 3:23 AM) *
I'm pretty sure you can, but I would soder, or use connectors if you can. I wouldn't want anything to go wrong with the RPM readings. Correct me if I'm wrong guys, but I believe you can splice into it.
-Ryan
post Mar 15, 2011 - 2:40 PM
cax_11
Joined Aug 15, '10
QUOTE (str8thugginit4ya @ Mar 15, 2011 - 11:16 AM) *
-Ryan
Ok thanks man, someone else told me that I can use G1 from the ECU, its a wire from the distributor
Nevis, West Indies
Lo-Fi Version Time is now: February 13th, 2025 - 6:09 AM
