![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) ![]() |
Can I just unbolt the valve cover, paint it, and bolt in back on?
Also, I've seen pictures of painting valve covers and things like the spark plug tube openings were sealed off. What exactly needs to be sealed? And what paint would you guys recommend? I'm thinking just a nice silver, maybe even red, I haven't decided. -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
buy a VC gasket set while you're at it. high temp engine paint is what you should use.
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
My VC gasket was replaced roughly 13k miles ago, still think I should?
buy RTV in that case. i'll be doing some painting tomorrow myself
![]() Enthusiast ![]() ![]() ![]() Joined Jan 30, '11 From Albany, NY Currently Offline Reputation: 4 (100%) ![]() |
yea best way is to take it off and paint it, just go to auto zone and get some high temp paint. Im prob just going to do it while its still on the lol
-------------------- ![]() Power in Balance 90 ST coupe- Sold 95 ST hatch- Dead :’( 02 Impreza RS- DD |
But the bolts have to be torqued down to certain specs when reinstalling, right?
'93 MX-5 LE |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) ![]() |
yup they do.
But the bolts have to be torqued down to certain specs when reinstalling, right? -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) ![]() |
It doesn't matter how long ago you replaced the gasket, once you take the vc off, you will want a new one as the gasket seat has been broken. Use high temp paint. And yes make sure to torque everything down correctly. At least I would change the gasket.
![]() -------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Alright, high temp paint and replace head gasket. Two questions answered, thanks guys! Now what do I need to seal off? The spark plug holes, the oil hole, the vacuum holes, anything else?
Valve cover gasket, not head gasket
Enthusiast ![]() ![]() Joined Dec 30, '09 From Wilmington, NC Currently Offline Reputation: 1 (100%) ![]() |
Inpsect the gasket if it only has 13k, it's probably alright, lube it with some oil before putting it back on, if it is OK. Kind of like you lube your oil filter before putting it on. Mask oil cap hole with masking tape and use a small file to form it to the circular shape. the tape will rip to the shape perfectly. Just roll up paper towels and stuff them in the spark plug holes and pcv hole. As for paint search for what you think you'll like. Main thing is prep, sand to like 400 grit before starting to paint or whatever the paint you use might recommend on the can. Here's a pic of my base coat with the valve cover masked off.
![]() This post has been edited by al94st: Mar 14, 2011 - 6:35 PM |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
^^^ correct if the gasket is still soft then its fine. you only need to replace it when its hard and brittle
Enthusiast ![]() ![]() Joined Dec 14, '10 From Lansing MI Currently Offline Reputation: 1 (100%) ![]() |
should have made a write up
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
and dont forget to put SEVERAL layers down. id use the whole damn can if i were you
timing is the key between intervals
![]() -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Thanks guys
![]() -------------------- taking too long to mod since '09
makes me want to paint mine
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
Same haha
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Lo-Fi Version | Time is now: February 20th, 2025 - 4:22 PM |
