> Help for 2DIN console, we want mount this..but
post Dec 6, 2003 - 5:07 AM
Sthen
Joined Dec 21, '02
From Europe Italy Lodi
I have one question...
In italy we don't have 2DIN central console,normally we mount a sigle DIN console.
So, i and some friends have buyed the 2DIN, the question is the following:
there is a frame to aid the fixing of the 2 different radio???
we need the item code and pics....
If you can we are very happy!!!!!
Ciao!!
Sthen Italy
post Dec 6, 2003 - 5:17 AM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
try t00251-02042 - it's the audio fitting for a Gen6 (T20 model) you get side brackets and the foam rubber and a smalll steel edge to go around the head unit.
post Dec 6, 2003 - 5:27 AM
Sthen
Joined Dec 21, '02
d you havesome pics of this?
it's original item?
Sthen Italy
post Dec 6, 2003 - 8:59 AM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
QUOTE (Sthen @ Dec 6, 2003 - 3:27 AM)
it's original item?
sorry no pics as it's installed in my car now..
it's a proper toyota item.
It's basically a left hand side bracket, right hand side bracket and a steel rectangle edge and some foam..
if you go into your local dealer they should be able to get the part in a few days.
they should also be able to check the part on the screen (you'll see an exploded view of the centre console with these bits highlighted.
BTW that code was for a right hand drive celica - the part may be different if your car is left hand drive.
This post has been edited by BenMMellor: Dec 6, 2003 - 9:00 AM
post Dec 12, 2003 - 11:43 AM
Sthen
Joined Dec 21, '02
TNX for your help i'll go to my toyota dealer to see it!!!
Ciao
Sthen Italy
Lo-Fi Version Time is now: January 16th, 2025 - 2:44 PM
