> Overheating problem, temp gauge all over the place
post Mar 21, 2011 - 6:30 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
My car has never had a temperature problem, always right in the middle of the gauge.
Today on my way to class, I noticed the temp went all the way up. Naturally i shut the car off and pulled over.
I decided to drive it back home since I wasn't far. I got home, checked the coolant level and THERE WAS NONE. Good job previous owner.
I filled it with coolant and expected it to be fine. Took it for a test drive and the temperate randomly fluctuates between really hot and normal.
It will climb high and then drop back down to normal very quickly and it repeats the process. I asked a guy I knew and he said maybe you have air in the system and to run it without the radiator cap for a while.
Anyone have any input? Appreciate it!!
post Mar 21, 2011 - 6:42 PM
mkernz22
Joined May 10, '10
From MA
cold start it with the radiator cap off and then slowly add more coolant so that you "burp" the system and you can also fully fill it as well
post Mar 21, 2011 - 6:58 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
QUOTE (mkernz22 @ Mar 21, 2011 - 7:42 PM) *
Okay cool. Coolant won't fly out of the rad with the cap off will it?
post Mar 21, 2011 - 7:17 PM
mkernz22
Joined May 10, '10
From MA
it shouldn't because it's being sucked down haha
just fill it until it's pretty close to the top
post Mar 21, 2011 - 7:33 PM
Turn your heater on hot, and fan on high while you do it.
NOVAKx17
Joined Oct 7, '09
As long as the car is cold when you start it there won't be any pressure for the radiator to force the coolant out, once you start it up start filling it with fluid... keep filling as needed until it is full and won't take any more.
NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold
1997 Celica ST- swapped and sold
2004 Ford explorer xlt 4x4- totaled
1997 Celica Convertible GT- Going Topless (;
(18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi
( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 )
post Mar 21, 2011 - 9:04 PM
TRD_Ian
Joined Aug 19, '08
From New Brunswick
dont blame the previous owner lol thats your own responsibility to check!. how many miles are on your car? id start worrying why you all of a sudden had no coolant, IE checking for leaks..if you had toyota coolant in it start looking for pinkish/red crusty residue for your problem prolly around your water pump area..when you go to "burp"the system make sure you have the proper mix ratio of water and coolant, watch your temp gauge and like manny said turn your heat up all the way and select the air to face for your blower that way its pushing the most air. fill up the rad and the res and start the car and just carefully watch its gonna bubble a bunch and wait for your thermo stat to open up u can tell this by your lower rad house i believe when it gets hot and you should also be able to see a bit of a swirl in the coolant once it opens up. i usualy speed up the process by reving the motor from the engine bay up around 3 grand to help it heat up. whole process should take about half an hr. but like i said id start looking in to why you had no coolant see when your timing belt and water pump were done last and checking for that coolant residue
i hate snow, missing my celica
post Mar 21, 2011 - 9:24 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
jack the front of the car up as high as you can, that will help get the bubbles up. no coolant wont come gushing out as long as you begin the process with the engine cold
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 21, 2011 - 9:35 PM
Neon90424
Joined Jan 19, '11
Maybe the car saw another celi
post Mar 21, 2011 - 10:24 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
Thanks for the hints guys, this will be my mission for tomorrow morning, hopefully it sorts it out.
@Neon...Funny you said that, I did pass a nice black (7thG)..cough cough...haha
I like my 6G though...Work in progress.
post Mar 21, 2011 - 11:05 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
How long til I know it's good guys?
Just until the rad and reservoir bottle are both full?
post Mar 21, 2011 - 11:57 PM
trdproven
Joined Aug 2, '05
From Guam
yea but reservoir bottle you fill manually after.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Mar 22, 2011 - 8:22 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you know its burped when you can feel hot air coming out the heater, like pressure said, turn the heater on full blast while you do this
post Mar 22, 2011 - 10:05 AM
bsamps4
Joined May 16, '10
From Raleigh
Make sure when you cap it off that you let it run for a little while just to check if you have any leaks in your radiator. Something similar happened to my car. I checked the coolant level before I bought it, and it was fine, but my radiator developed a few leaks and had to be replaced.
post Mar 22, 2011 - 11:03 AM
Mycurse180
Joined Dec 23, '10
From PA, USA
All fixed!
post Mar 22, 2011 - 12:13 PM
zfjohnson07
Joined Apr 11, '09
what was it
post Mar 22, 2011 - 7:30 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
QUOTE (zfjohnson07 @ Mar 22, 2011 - 1:13 PM) *
what was it
I just did what you guys said..."burped the system". All good now.
Thanks again.
post Mar 23, 2011 - 10:14 AM
injection
Joined Jan 10, '11
From Trail BC
QUOTE (Mycurse180 @ Mar 22, 2011 - 8:30 PM) *
what was it
Thanks again.
Keep an eye on your headgasket, your factory temp gauge isnt that accurate, and by the time you get to 3/4 high on gauge, its to late. your car shut off, so thats good...hopfully just in time.
what was it
Thanks again.
what was it
Thanks again.
Keep an eye on your headgasket, your factory temp gauge isnt that accurate, and by the time you get to 3/4 high on gauge, its to late. your car shut off, so thats good...hopfully just in time. if any problems, look for white smoke out your exhaust...good indication
post Mar 23, 2011 - 1:23 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
I don't think any damage was done. I shut it off as soon as I saw it get hot, let it cool off then limped it home.
I did the "burp" thing and temp stays perfect, runs fine again, it's all good.
post Mar 28, 2011 - 7:49 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
It strikes again!
I overheated and this time I caught anti freeze leaking by my serpentine belt [or whatever] and I'm pretty sure it's my water pump that's leaking!
I kept pouring water in to my reservoir and limped it home. It did get hot a couple times...I fking hope I didn't do any damage to my engine.
Lo-Fi Version Time is now: November 30th, 2024 - 4:44 PM
