> manifold
post Dec 6, 2003 - 3:32 PM
jmastaniza
Joined Nov 29, '03
From Auburn, ca
will the 3sgte intake manifold fit the 5sfe?
This post has been edited by jmastaniza: Dec 6, 2003 - 3:47 PM
post Dec 6, 2003 - 3:43 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (jmastaniza @ Dec 6, 2003 - 1:32 PM)
will the 3sgte inake manifold fit the 5sfe?
Yes.
3sgte,3sge,5sfe and 3sfe exhaust manifolds are all the same bolt pattern and can be swapped for each other.
-Bryan-
Member of Team 5sfTe
post Dec 6, 2003 - 3:48 PM
jmastaniza
Joined Nov 29, '03
From Auburn, ca
i know the exhaust fits but ive never seen anyone swap the intake manifold.
post Dec 6, 2003 - 3:50 PM
Mynzeyes
From Franklin/Nashville, TN
why would you bother? you could always just port/polish/gasket match your intake manifold if you are wanting better flow...
AIM==Mynzeyes
post Dec 6, 2003 - 3:53 PM
jmastaniza
Joined Nov 29, '03
From Auburn, ca
thought it might be better if i was going to go with a TMIC
post Dec 6, 2003 - 3:55 PM
Andason
Joined Jun 26, '03
From Wisconsin
QUOTE (jmastaniza @ Dec 6, 2003 - 1:53 PM)
For as many plans as it sounds like you have I highly recommend just going all out and doing the swap. You'll have a TMIC and it'll do something, you'll have a motor already built for turbo, less worry about straining your motor, and no major custom work required.
Do the 3sgte.
i am awesome
post Dec 6, 2003 - 3:59 PM
1bwilson
Joined Aug 30, '02
From Maryland
You cant use a TMIC with the 5sfe. There is NO WAY for it to fit. The 5sfe head is to narrow.
Sorry I misread your post. No the IM will not fit either. Your best bet is to get one from (Biscutwheels from celica.net still in its WIP stage) one from (ITZITS aka Aaron fowler from http://board.mr2faq.com His are ready apon request. He has one with a 65mm mustang TB for sale right now for 375) Last you can use a IM from a japan 3sfe. It uses 2 runners per port where as the 5sfe and 3sfe from the states has just one and the #4 cylinder gets bad air flow.
-Bryan-
post Dec 6, 2003 - 4:42 PM
Jabberwock
Joined Sep 22, '03
dude, you posted this just for TMIC purpose and you already have one on that.
Just put it into one post.
Just do the swap because it will cost the same or less then all the things it seems you are planning to do.
With the 5SFTE with all 3SGTE parts will end up exactly the same except for all your internals will be worse off then just the SWAP.
post Dec 7, 2003 - 1:16 AM
jmastaniza
Joined Nov 29, '03
From Auburn, ca
sorry bout that. wont let it happen again.
Lo-Fi Version Time is now: January 15th, 2025 - 11:52 PM
