2 Pages V  < 1 2
> 3rd Gen 3sgte w/ E153 Swap Thread, Clutch and flywheel are here.
post Mar 31, 2011 - 6:30 PM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (mak5603 @ Mar 31, 2011 - 2:10 PM) *
QUOTE (Ted95 @ Mar 31, 2011 - 6:54 AM) *
QUOTE (mak5603 @ Mar 30, 2011 - 10:10 AM) *
Just working on ordering the remaining stuff I need. I'm buying an Exedy stage 2 clutch and possibly a flywheel. I have a question for some of you, and I know this is kind of vague..but do you think daily driving is still going to be manageable with a Fidanza flywheel or should I probably just resurface my stock flywheel? I've driven light flywheels, but never on a FWD car or car with this much power, so I am kind of stuck and don't know what to do.
Another question, where are you swappers getting your hoses? Anywhere in particular? Something I gotta start keeping an eye out for.
Thanks in advanced guys!
for my swap, im just reusing the stock 3sgte flywheel and resurfacing it. i was going to get a ultra light weight flywheel but i was told by some of the motor heads its really not worth it for the money, unless your going to go big downt he road i guess. so im using the stock flywheel, thats just me.
and im reusing the 5sfe hoses as long as they are good, most of them will be reuseable, some you just have to buy some hose and make it work lol.
Yeah, I should have specified. I was more talking Samco or other silicon hoses, there are a couple that I need. I can reuse a few. I changed my clutch decision, so that may change my ultimate flywheel decision as well. We'll see by the end of the day, haha.
ya i tried looking up a new 3sgte hose kit, like brand new factory hoses but i couldnt find them.. unless someone else knows where i can get them?
st205 powered ss3 coupe
post Mar 31, 2011 - 8:52 PM
You can get the rad hoses off eBay.
Berk technology sells a high quality silicone hose kit for the mr2 that uses the same size hoses (umm yes....because it's the same engine) for all of the smaller ones.
post Mar 31, 2011 - 10:20 PM
mak5603
Joined Oct 20, '08
QUOTE (presure2 @ Mar 31, 2011 - 6:52 PM) *
Yeah, I knew about the radiator hoses, but that is exactly what I was looking for as far as the other ones go. Funny because I looked at Berk's site and after I didn't see anything under the MR2 stuff, I didn't bother checking the vacuum line section *facepalm*. Thank you, going to order that set tonight. smile.gif
2014 Toyota Rav4 XLE
post Apr 3, 2011 - 12:18 PM
mak5603
Joined Oct 20, '08
Ordered some more stuff..
Now it's time for my ultimate clutch / flywheel decision. After weighing my options for literally months, and changing my mind over 5-10 times, I think I know what I want. My number one goal is to pick a setup that will be fun, but easily daily able. My goal is to daily the 3s celi. So with that said, I originally wanted to go with an ACT 6 puck, Fidanza flywheel, then Exedy stage 1 Fidanza flywheel. But the first option was too "non street" for me, and the second was stretching the limits of the max torque capacity of the clutch with my 3s, which I don't want for obvious reasons. Then I got to thinking, I don't even want an 8lb. flywheel. I than found a 12 pound steel flywheel, which I would way rather have (I have read stories where aluminum flywheels can do bad things under high heat, mainly after track use) from Competition Clutch. They also offer a Stage 2 clutch, both items go hand in hand and are recomeded for higher hp street applications.
So I think I am going to try out the Competition Clutch Stage 2 clutch and Competition Clutch Light (Not ultra light) Steel Flywheel. What you guys think?
post Apr 3, 2011 - 3:35 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Thats actually the clutch kit im looking at for when i swap, i believe tweak sells them, but wouldnt it just be the same as a clutch set up from the MR2 turbo?
2001 Solar yellow Lexus IS300
post Apr 3, 2011 - 4:10 PM
mak5603
Joined Oct 20, '08
QUOTE (96stgreendemon @ Apr 3, 2011 - 1:35 PM) *
I know the flywheel is the same. For my swap the clutch is the same as Mr2 because I am using an e153.
post Apr 3, 2011 - 5:51 PM
I am running a comp clutch I got thru tweak.
I won't run another.
Pedal feel is horrible(ie: very heavy), totally sucks for daily driving, and is very on/off, even after almost 2 years. It also feels like it's starting to slip a little when I go 3rd gear pulls on the highway @ high boost (19-20psi) which is ~ 320whp or so. The only good point of that clutch was it was cheap. like almost 100$ cheaper than what I was going to get at the time.
the next clutch I buy will be a clutchmasters. I'll definitely spend the extra money.
My cousin has a stage 4 unsprung that has better engagement and lighter pedal feel than both the comp I'm running, and the act hd pp.
I've driven several different setups over the years,(act, spec, centerforce, competition) the centerforce was is by far the best one Ive felt so far, especially since it's got great pedal feel, and can still hold 400ft lbs all day.
And yea if your running the E153, any mr2t or alltrac clutch will bolt on.
post Apr 4, 2011 - 2:14 PM
match220
Joined May 13, '06
From Kaimuki, HI
nice, I'm doing the same swap
This post has been edited by match220: Apr 4, 2011 - 2:16 PM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Apr 5, 2011 - 1:05 PM
mak5603
Joined Oct 20, '08
QUOTE (presure2 @ Apr 3, 2011 - 3:51 PM) *
Not what I like to hear and definitely not the first time I've heard such complaints. kindasad.gif Looks like that clutch is out of the picture for me now. I still like the flywheel, but now I'm back to looking for a good street clutch.
post Apr 12, 2011 - 5:35 PM
mak5603
Joined Oct 20, '08
More boring stuff came in this week that I will be putting on.
I repainted my valve cover a glossier red.
Last but not least I officially ordered my clutch and flywheel. Went with Clutch Masters FX300 (Stage 3) clutch and Competition Clutch lightweight steel 12 pound flywheel. Now I'm just waiting for those things to come in and I should be just about ready to go. smile.gif
post Apr 21, 2011 - 11:36 PM
mak5603
Joined Oct 20, '08
Almost set to go.
This post has been edited by mak5603: May 7, 2012 - 1:24 PM
post Apr 22, 2011 - 7:14 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
post Apr 22, 2011 - 8:13 PM
QUOTE (mak5603 @ Apr 12, 2011 - 6:35 PM) *
let me know how you like that clutch..my cousin has a stage 4 unsprung, with stock fw, and it feels sooo nice compared to the stage 4 sprung comp. clutch i have.
post Apr 26, 2011 - 1:58 PM
mak5603
Joined Oct 20, '08
QUOTE (presure2 @ Apr 22, 2011 - 6:13 PM) *
Will do for sure. I'm really excited to feel this setup.
I went with stage 3 because I don't want a "puck" clutch for my daily.
post May 23, 2011 - 7:58 PM
mak5603
Joined Oct 20, '08
Was really hoping to be driving this by now. Unfortunately I haven't touched it in weeks as I am still waiting for my axles, ecu, and intake from the person I bought it from... Supposedly they are coming, but such has been the story for a year now, so we will see. No use doing anything until I have everything ready.
It's really bumming me out and I'm really starting to lose interest in this project. frown.gif I want a 3s celi bad, but this wait it BS. My motor can't be stored where it is forever as I don't own the warehouse, so if the stuff doesn't come soon I don't know what I am going to do frown.gif
post May 23, 2011 - 9:26 PM
brenton1919
Joined Feb 28, '11
QUOTE (mak5603 @ Mar 30, 2011 - 9:10 AM) *
im running the clutch master light weight flywheel with a stage 1 clutch on my set up.................. i hate it i hate it i hate it i hate it.............. lol.. u wanna talk about slipping i cant even down shift the dang thing all u smell is clutch. i back out the drive way all u smell is clutch.. i have many cars with way more hp than my caldina set up.. but ive never seen a car this bad im gonna change my set up soon
post Jun 9, 2011 - 3:51 PM
mak5603
Joined Oct 20, '08
Got my ECU today.
Hopefully soon I will receive axles and intake. Then finally able to get this beast in the bay where it belongs.
post Jul 14, 2011 - 12:25 PM
mak5603
Joined Oct 20, '08
Stiiiiiiiiiiiill waiting for my axles and intake... Motors just chillin in my storage unit, looking pretty. Switched a couple things up. Bought a FMIC with welded piping fit up for a 3s, so I'm pretty excited about that. Also repainiting a couple pieces.
I really hope to have some more updates soon. Jim says axles should be in too him within a week, then on too me...but we'll see. Getting pretty bored of the 5s, haha, I never pay attention to this car anymore.
Anyways, if anyone needs a E154f, W2A intercooler, Apexi AFC NEO, or turbo xs rfl bov, let me know.
This post has been edited by mak5603: Jul 14, 2011 - 3:37 PM
2 Pages V  < 1 2
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: December 4th, 2024 - 2:36 PM
