Interior fuse panel????, Need diagram....PLEASE,, |
Mar 25, 2011 - 12:18 PM |
Enthusiast Joined Jan 10, '11 From Trail BC Currently Offline Reputation: 1 (100%) |
Hey 6th genres, would somebody be kind enough to send me, or post a diagram of the interior fuse box for a 94 celica GT....I lost the diagram on the inside of the panel door, and now need it. Even taking a good picture of yours and sending it to me would be a huge!! Help, as I have no reference to what each fuse is for there.. Thanx,
Mar 25, 2011 - 12:25 PM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
If its the same as a '95 GT I can grab you a pic in no time.
Mar 25, 2011 - 12:29 PM |
Mar 25, 2011 - 12:34 PM |
K, I'll brb with the pic.
Mar 25, 2011 - 12:41 PM |
Heres the diagram:
And heres a pic of the fuse box: |
Mar 25, 2011 - 1:05 PM |
Heres the diagram: And heres a pic of the fuse box: Thanx so much! Awesome man, you have no idea how much this helps me out, just did 205 swap car turns over great, but no spark???? And I have no power to 2-3 fuses in there, think it's the problem, considering no power to the 7.5 amp one which from what I can see on your diagram, has something to do with ignition, I hope, |
Mar 25, 2011 - 1:08 PM |
No problem.
Switch panel fuse for a quick test? Also did you check the front fuse box because I believe there is an ignition fuse there too but idr. My cig lighter jack thingy isn't working but it can't be the fuse cause my radio works any idea on that? |
Mar 25, 2011 - 1:35 PM |
No problem. Switch panel fuse for a quick test? Also did you check the front fuse box because I believe there is an ignition fuse there too but idr. My cig lighter jack thingy isn't working but it can't be the fuse cause my radio works any idea on that? Travisx, I would replace your lighter, the thing that pops when it's hot, I believe what has happened is your element has burnt out....you can pick up a universal one at your local automotive store, they may have to order one for you, but know question about it, you can get one for it, thanx again, nice clear pics too! |
Lo-Fi Version | Time is now: December 3rd, 2024 - 8:41 AM |
