> I NEED HELP! Anyone know how to change out the thermostat?, Please read!
post Mar 25, 2011 - 4:20 PM
JDUB
Joined Jun 5, '08
From Portland, Oregon
Im in need of changeing my thermostat and is wondering if anyone can help me out a lil bit, also I see that theres some mocha colored gunk in my oil cap, does that mean i have a leaky headgasket? My car takes a long time to warm up , im thinkin due to the thermostat being stuck open, could that be the cause of the coolant gettin mixed in my oil? No smoke or nothing just finding the mocha stuff under my oil cap.
post Mar 25, 2011 - 4:51 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
If your coolant is mixing with your oil its your headgasket that is the problem, not the thermostat
2001 Solar yellow Lexus IS300
post Mar 25, 2011 - 8:04 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
QUOTE (JDUB @ Mar 26, 2011 - 10:20 AM) *
Apparently that's the tell-tail sign of a BHG.
Mike W
269awhp / 273ft-lbs
post Mar 25, 2011 - 8:56 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
or its just normal condensation that never gets vaporized out of the oil because the engine never reaches full operating temp.
post Mar 25, 2011 - 9:36 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
the cap collects that crap, what does the coolant look like? regardless you need to replace the thermostat. is this an ST or GT. search my rebuild threads i have tons of pics where they are
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 25, 2011 - 9:45 PM
clownpRon
Joined Oct 24, '10
From Chicago
Follow your lower radiator hose to the engine.
post Mar 25, 2011 - 10:15 PM
QUOTE (Bitter @ Mar 25, 2011 - 9:56 PM) *
X2
post Mar 26, 2011 - 6:43 AM
trdproven
Joined Aug 2, '05
From Guam
if it is also mixing into your radiator coolant, then thats blown HG.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Mar 26, 2011 - 12:51 PM
JDUB
Joined Jun 5, '08
My coolant is still full and green, soo what does it mean now? lol
post Mar 26, 2011 - 1:06 PM
Bitter
Joined Mar 11, '06
I think it means people cry blown head gasket too easily and don't fully know what they're talking about.
post Mar 26, 2011 - 1:52 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (presure2 @ Mar 25, 2011 - 11:15 PM) *
X2
Thats what Im leaning towards. If all you other fluids look fine (oil, coolant) then change the thermostat. Then just keep an eye on things. I had the same issue for a bit (as far as taking forever to warm up), but changed my thermostat and it warms up fairly quick (as opposed to before).
And I see you have the GT. So changing out the thermostat is kind of a pain as the compressor (if you have ac) and oil filter get in the way. But remove the water neck (two 10 mm nuts, real soft too so be careful) along with the lower radiator hose and you'll see your thermostat. Just make sure that if you get one with a "jiggle valve" you align it with the mark on the water neck. Reinstall and hook everything back up, refill and your good to go. And I replaced my crap nuts with some nylon locknuts (as they are not as soft).
This post has been edited by Spider77: Mar 26, 2011 - 1:57 PM
post Mar 26, 2011 - 7:32 PM
zfjohnson07
Joined Apr 11, '09
lol its easy to change out on a gt, took me about 10 minutes and im lazy. find that how to it helps!
post Mar 27, 2011 - 9:04 PM
Araykhel
Joined Sep 21, '10
From Woodstock, MD
Replacing the thermostat in the GT is pretty easy. Just be sure to take the oil filter off to get some leverage on the 10 mm bolts holding the housing. The pitchcock to drain the coolant is right below where you'd think it is on the front left, however you will need to take off at least one of the plastic underbody panels, just a few 14mm bolts there. Before you pull the radiator hoses off make sure you press them firmly to push any fluids out, believe me it can get messy.
Lo-Fi Version Time is now: January 10th, 2025 - 6:04 AM
