3sgte swap/ still no spark??, Have power going to coil on acc. ( both sides ) |
Mar 27, 2011 - 2:52 PM |
Enthusiast Joined Jan 10, '11 From Trail BC Currently Offline Reputation: 1 (100%) |
i'm pretty sure if the resistor went out you wouldn't be getting fuel pressure. Do you get a signal from the cam sensor at all? You should see a on off on off on off type of signal correct? I will have to check that, when home from work, I will check the fuel resister first, Manuel says operation is 0.73ohms. Anything else, replace. Where exactly is the cam sensor.... Distributer side or timing belt side??? if you had your harness done by tweak then its right check the Distributer coil wen im working on cars and they wont start i find this to be my problem most of the time check your relay's fuses and make sure your engine is grounded your fuel has nothin at all to do with your car not gettin spark i can tell u that right now check your starter relay to by the ecu but if u have power going to the Distributer then your problem is the coil i can put my money on it and if not then its your ecu its not gettin the signal to the Distributer coil telling it to spark your ecu might be bad but if your have power to the Distributer there is no reason at all u should not be getting a spark unless u have a bad coil and remember just because its new doesn't mean its good they seel bad coils all the time make sure your rotor button is good to it maybe bad or your cap Hey Brenton, well, my issue is have no spark from discharge in coil to cap, I have power to coil + and - but I have no pulse when cranking, same with injectors....I hear what your sayin about Tweak, he does do awesome work, very impressed with how clean and perfectly routed my harness is,checked every wire at ECU, and all is correct.... Pulled distributer off and tested, G1, G2 checked out at 154ohms and NE+ was 190ohms and of course G- is ground, that I tested from, and from what I can tell, it is in good shape within ohm spec, today when home from work will hook coil directly up to battery to see if I can get discharge to arc...then I will know if it's shot or not. If nothing comes out.....anymore thoughts man?? |
Mar 27, 2011 - 3:21 PM |
Enthusiast Joined Feb 28, '11 Currently Offline Reputation: 5 (100%) |
i'm pretty sure if the resistor went out you wouldn't be getting fuel pressure. Do you get a signal from the cam sensor at all? You should see a on off on off on off type of signal correct? I will have to check that, when home from work, I will check the fuel resister first, Manuel says operation is 0.73ohms. Anything else, replace. Where exactly is the cam sensor.... Distributer side or timing belt side??? if you had your harness done by tweak then its right check the Distributer coil wen im working on cars and they wont start i find this to be my problem most of the time check your relay's fuses and make sure your engine is grounded your fuel has nothin at all to do with your car not gettin spark i can tell u that right now check your starter relay to by the ecu but if u have power going to the Distributer then your problem is the coil i can put my money on it and if not then its your ecu its not gettin the signal to the Distributer coil telling it to spark your ecu might be bad but if your have power to the Distributer there is no reason at all u should not be getting a spark unless u have a bad coil and remember just because its new doesn't mean its good they seel bad coils all the time make sure your rotor button is good to it maybe bad or your cap Hey Brenton, well, my issue is have no spark from discharge in coil to cap, I have power to coil + and - but I have no pulse when cranking, same with injectors....I hear what your sayin about Tweak, he does do awesome work, very impressed with how clean and perfectly routed my harness is,checked every wire at ECU, and all is correct.... Pulled distributer off and tested, G1, G2 checked out at 154ohms and NE+ was 190ohms and of course G- is ground, that I tested from, and from what I can tell, it is in good shape within ohm spec, today when home from work will hook coil directly up to battery to see if I can get discharge to arc...then I will know if it's shot or not. If nothing comes out.....anymore thoughts man?? did u check the ignitor if u have power to the Distributer coil and your ignitor is good check your relays tho's will really get you but i really think its the coil the cap rotor botton relay or ignitor try to get a another Distributer the whole thing see what happens i really have that problem alot when imm working on peoples car those coils gooo outt alll the timeeee and i put a new one on and bam it starts righttt upp but i really think it has nothin to do with the wires tweak has been doing them to long to mess them up wat gen do you have i think the 3rd gen has a cam sensor it should still spark if its bad the car just wont be in time take the cam sensor out and try to pick up something metal with it if it doesn't pick up anything its bad if that is the Distributer coil that came with the engine and you never got a new one im almost sure that that is your problem |
Mar 27, 2011 - 3:36 PM |
are you saying you don't have pulse signal to distributor cap and injectors ?
Mar 27, 2011 - 4:02 PM |
3rd gens do not have a cam sensor..(well, technically, the do, but it's part of the distributor.
13.6@108MPH, 5SFTE Powered |
Mar 27, 2011 - 4:10 PM |
Mar 27, 2011 - 4:18 PM |
are you saying you don't have pulse signal to distributor cap and injectors ? Yes, when cranking, have no pulse signal to cap......just a constant power, it might be your ecu if your not getting a signal call tweak tomorrow and ask him can he look at your ecu this is why i got a caldina i have c.o.p's and dont have to worry about the Distributer and ignitor just my crank sensor c.o.ps and cam sensor |
Mar 27, 2011 - 4:43 PM |
are you saying you don't have pulse signal to distributor cap and injectors ? Yes, when cranking, have no pulse signal to cap......just a constant power, and injectors ? if both systems are affected, I would look into the COR -------------------- |
Mar 27, 2011 - 5:11 PM |
are you saying you don't have pulse signal to distributor cap and injectors ? Yes, when cranking, have no pulse signal to cap......just a constant power, and injectors ? if both systems are affected, I would look into the COR Yes, no pulse at injectors either..... |
Mar 27, 2011 - 5:36 PM |
Enthusiast Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
so looks like either something with the ecu or dizzy. Correct? The injectors won't pulse unless having a signal from the dizzy.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Mar 27, 2011 - 5:38 PM |
Mar 27, 2011 - 5:59 PM |
so looks like either something with the ecu or dizzy. Correct? The injectors won't pulse unless having a signal from the dizzy. Does dizzy stand for distributer.....sorry, had to ask, is that what you mean though, if so Brenton told memto replace it, can't I just replace the pick-up coil inside, or should I just get a whole new one. |
Mar 27, 2011 - 6:12 PM |
so looks like either something with the ecu or dizzy. Correct? The injectors won't pulse unless having a signal from the dizzy. Does dizzy stand for distributer.....sorry, had to ask, is that what you mean though, if so Brenton told memto replace it, can't I just replace the pick-up coil inside, or should I just get a whole new one. I will say this to you guys, I had spark before harness was sent out........I get harness back 2 months later, and now no spark.....think that's why it makes this so much more confusing, because it's hard to believe a part would just go on my car in that time the harness was gone, I guess it's because of coinsidence, that I'm suspect of the harness, cause the car would barely roll over twice before firing, now nothing???????? |
Mar 27, 2011 - 6:22 PM |
Mar 27, 2011 - 6:32 PM |
so looks like either something with the ecu or dizzy. Correct? The injectors won't pulse unless having a signal from the dizzy. Does dizzy stand for distributer.....sorry, had to ask, is that what you mean though, if so Brenton told memto replace it, can't I just replace the pick-up coil inside, or should I just get a whole new one. I will say this to you guys, I had spark before harness was sent out........I get harness back 2 months later, and now no spark.....think that's why it makes this so much more confusing, because it's hard to believe a part would just go on my car in that time the harness was gone, I guess it's because of coinsidence, that I'm suspect of the harness, cause the car would barely roll over twice before firing, now nothing???????? What ECU cables to ground?? Wait does ECU need to be bolted down to centre console on bracket, to be grounded??? |
Mar 27, 2011 - 6:55 PM |
so looks like either something with the ecu or dizzy. Correct? The injectors won't pulse unless having a signal from the dizzy. Does dizzy stand for distributer.....sorry, had to ask, is that what you mean though, if so Brenton told memto replace it, can't I just replace the pick-up coil inside, or should I just get a whole new one. I will say this to you guys, I had spark before harness was sent out........I get harness back 2 months later, and now no spark.....think that's why it makes this so much more confusing, because it's hard to believe a part would just go on my car in that time the harness was gone, I guess it's because of coinsidence, that I'm suspect of the harness, cause the car would barely roll over twice before firing, now nothing???????? What ECU cables to ground?? Wait does ECU need to be bolted down to centre console on bracket, to be grounded??? the ecu does not have to be bolted in. here are the specs for the 3rd gen distributor. -------------------- Former Team 5SFTE pro member ;)
Mar 27, 2011 - 9:27 PM |
so looks like either something with the ecu or dizzy. Correct? The injectors won't pulse unless having a signal from the dizzy. Does dizzy stand for distributer.....sorry, had to ask, is that what you mean though, if so Brenton told memto replace it, can't I just replace the pick-up coil inside, or should I just get a whole new one. I will say this to you guys, I had spark before harness was sent out........I get harness back 2 months later, and now no spark.....think that's why it makes this so much more confusing, because it's hard to believe a part would just go on my car in that time the harness was gone, I guess it's because of coinsidence, that I'm suspect of the harness, cause the car would barely roll over twice before firing, now nothing???????? What ECU cables to ground?? Wait does ECU need to be bolted down to centre console on bracket, to be grounded??? so looks like either something with the ecu or dizzy. Correct? The injectors won't pulse unless having a signal from the dizzy. Does dizzy stand for distributer.....sorry, had to ask, is that what you mean though, if so Brenton told memto replace it, can't I just replace the pick-up coil inside, or should I just get a whole new one. I will say this to you guys, I had spark before harness was sent out........I get harness back 2 months later, and now no spark.....think that's why it makes this so much more confusing, because it's hard to believe a part would just go on my car in that time the harness was gone, I guess it's because of coinsidence, that I'm suspect of the harness, cause the car would barely roll over twice before firing, now nothing???????? What ECU cables to ground?? Wait does ECU need to be bolted down to centre console on bracket, to be grounded??? |
Mar 27, 2011 - 10:10 PM |
Now that you said that Brenton, I did mount a wire behind the intake manifold, on a 10mm bolt the wire had an end that excepted that bolt, n screwed it tight to back of manifold. From the harness
Mar 27, 2011 - 10:57 PM |
Now that you said that Brenton, I did mount a wire behind the intake manifold, on a 10mm bolt the wire had an end that excepted that bolt, n screwed it tight to back of manifold. From the harness Ok just tested coil with battery + - and had a very very small spark on coil wire ( discharge ) end, to screwdriver, is this spark supposed to be big n bold, or barely able to see it????? Cause that's what it was...really had to look for the spark???? |
Mar 27, 2011 - 11:38 PM |
Mar 27, 2011 - 11:52 PM |
Now that you said that Brenton, I did mount a wire behind the intake manifold, on a 10mm bolt the wire had an end that excepted that bolt, n screwed it tight to back of manifold. From the harness Ok just tested coil with battery + - and had a very very small spark on coil wire ( discharge ) end, to screwdriver, is this spark supposed to be big n bold, or barely able to see it????? Cause that's what it was...really had to look for the spark???? K man, I am gettin one tomorrow.....keep my fingers crossed, the scary thing is, if this doesn't work, I don't know what else it could be???? |
Lo-Fi Version | Time is now: November 27th, 2024 - 12:31 AM |
