> No interior lights, etc
post Mar 27, 2011 - 3:19 PM
block
Joined Jul 27, '06
From Soda
After I plugged in the new battery, car started, but nothing in the interior is working - lights, wipers, turn signals, ac, heat! This car is starting to piss me off. I checked all the fuses and they all looked good. Anyone might know another way of looking at this? LMK I need to get my car out of my parent's garage and can't drive it until everything works. mad.gif
post Mar 27, 2011 - 4:11 PM
mkernz22
Joined May 10, '10
From MA
with my car, the interior fuse panel was f*cked up and the exterior driving lights (except for the headlights) would go on and off at random times. I replaced the fuse panel and it's worked fine now
post Mar 27, 2011 - 4:15 PM
block
Joined Jul 27, '06
From Soda
Damn. Everything was working fine until I replaced the battery. There were a few sparks with the + but I thought it was normal. Went to start my car, started up, and none of my power windows, power door locks, interior lights, gauge lights, wipers, nothing worked! Well, my headlights worked haha. It's pissing me off. I dont want to have to replace the whole damn thing mad.gif
post Mar 27, 2011 - 4:30 PM
mkernz22
Joined May 10, '10
From MA
That usually is normal, which is weird. did you put the positive side on first or the negative?
post Mar 27, 2011 - 4:33 PM
block
Joined Jul 27, '06
From Soda
+ went in first. That's what I thought...sparks are normal. FUDGE!!!!!!!!!!!!!!!!!!!! I was hoping to get it up and ready to go and then this crap happens...UGH!
post Mar 27, 2011 - 7:41 PM
block
Joined Jul 27, '06
From Soda
Ok went back and found out ALT Fuse went out...it's fuse 100A (BLUE). That fuse was a bitch to get out because it has two screws hidden down bottom you had to unscrew. Unbolted fuse panel, unbolted plastic surrounding, and unscrew the damn two screws. Sheesh, I'm done.
post Mar 29, 2011 - 2:20 PM
95celgt
Joined Oct 5, '03
From South TX.
so now it works?
my map lights dont work, my clock memory doesnt stay, and my factory radio harness doesnt supply 12v memory constant.
when i TRY to turn on my map lights my clock turns off completely.
Lo-Fi Version Time is now: November 27th, 2024 - 5:39 AM
