Tanabe Drop with 7th gc wheels? |
Mar 28, 2011 - 6:19 PM |
Enthusiast Joined Mar 25, '11 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
Hey guys I have tanabe df210 springs coming to me right now with kyb gr2 struts but I'm a little concerned. My 6gc wheels and tires are off a 7gc gts wheels and tires... Which are 16" wheels if I'm correct... Now the tanabe df210 says they drop 2.2" front and 1.5" rear. Will my front wheels be hitting my chassis? I measured it but it seems really close and it's not an exact exact measurement so I'm just wondering if anyone else did this kind of drop and will I make it without hitting the chassis? Any pictures?
Thanks Gerald |
Mar 28, 2011 - 8:20 PM |
You're fine.
'93 MX-5 LE |
Mar 28, 2011 - 10:04 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
Ha....ha.....ha....
hitting chasis...... I wonder when Im gonna hit chasis? Spolski had the best 6 on Tanabe springs -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Mar 28, 2011 - 11:10 PM |
Hahahaha thanks guys(: just a little paranoid:/ cuz I have springs that hit my 2007 camry SE chassis lol but that's prolly because I had bigger wheels(:
This post has been edited by hizzle369: Mar 28, 2011 - 11:10 PM |
Mar 29, 2011 - 10:46 AM |
Enthusiast Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
Lol, yea. You're gonna have to go a lot lower than that to hit chassis. The Camry was probably just rubbing the fender. So IF anything happens to rub, you probably would just need a small camber adjustment. You can talk to 808Celica or HarolFastwaker about that, or other member who know about camber. Hope you guys don't mind me using your names.
-Ryan |
Mar 29, 2011 - 12:11 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
You wont need to run neg camber with that set up, im running very little negative camber with a 2.5 in drop and 25mm spacers and i rub very very rarely on the front fender, back had to be rolled, but thats another story
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Mar 29, 2011 - 4:58 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Have the same suspension/wheel setup in this pic... NO RUB RUB.
You're good. -------------------- |
Mar 29, 2011 - 10:00 PM |
I rub... But again 2.5 in drop and 25mm spacers
Mar 30, 2011 - 3:40 AM |
I rub ALL NIGHT LONG.......
ask me anything if you dare -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Mar 30, 2011 - 8:25 AM |
I have come to realize that rubbing is all part of lowered cars lol, and scraping, lots of scraping, but Low is a Lifestyle
Mar 30, 2011 - 3:05 PM |
HAve you bent a control arm yet you Low Life Son of a.............
Apr 6, 2011 - 10:53 PM |
Will I be needing wheel spacers for this drop?
Apr 6, 2011 - 10:55 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Will I be needing wheel spacers for this drop? Depends on your wheels' offset. Not the drop. -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Apr 6, 2011 - 11:25 PM |
Will I be needing wheel spacers for this drop? view the pics a few posts up - mine have no spacers, but stgreendemons do. -------------------- |
Apr 7, 2011 - 1:09 AM |
do your tires wear out fast without the spacers?
Apr 7, 2011 - 1:14 AM |
do your tires wear out fast without the spacers? That mostly depends on the camber, not the spacers. The spacers just bring the wheels out horizontally. But those springs shouldn't drop it enough to where a normal alignment can't adjust the camber. Even then, there's always camber bolts. But you won't need camber bolts. This post has been edited by HectortheRican: Apr 7, 2011 - 1:15 AM -------------------- taking too long to mod since '09
Apr 7, 2011 - 9:08 AM |
do your tires wear out fast without the spacers? That mostly depends on the camber, not the spacers. The spacers just bring the wheels out horizontally. But those springs shouldn't drop it enough to where a normal alignment can't adjust the camber. Even then, there's always camber bolts. But you won't need camber bolts. Correct No unusual tire wear from my set up. -------------------- |
Apr 12, 2011 - 10:33 PM |
Another question popped into mind!
I just had a friend told me that with that large of a drop; 2.2" the KYB Gr-2's might not be able to sustain the shocks. Is that true? Like it doesn't absorb enough causing the shocks to blow... But I'm guessing Kaos, that you've had the Tanabe DF210s + KYB Gr-2s for a while right? Also; Will I be needing Bumpstops; is this gonna bottom out? I will be installing tomorrow. This post has been edited by hizzle369: Apr 12, 2011 - 11:45 PM |
Lo-Fi Version | Time is now: December 1st, 2024 - 5:58 PM |
