> Trunk won't pop unless lifting up at the same time
post Mar 29, 2011 - 2:27 PM
Con99vert
Joined Aug 27, '09
From Las Vegas
If I pull the handle to pop the trunk it will not open unless somebody is standing back there to lift up on the trunk lid. The same thing if I use the key to pop the trunk. Is there a spring, or an adjustment of some sort that can take care of this?
This post has been edited by Con99vert: Mar 29, 2011 - 2:27 PM
JayLas Vegas1999 GT ConvertibleASC #2346
FOR SALE!!!
post Mar 29, 2011 - 4:48 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
It'll un-latch though, right? Then you just pull it up? That's what I do with mine. I think that's how it's supposed to work... We don't have fancy-smancy cars lol
June '12 COTM
'95 AT200
post Mar 29, 2011 - 5:28 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
I have this problem sometimes. Hector he means he pulls the lever, he hears it open(the 1"it opens),lets go of the lever,goes to the back and finds the trunk locked..
post Mar 29, 2011 - 5:31 PM
HectortheRican
Joined Dec 26, '09
Alright, that's why I asked. Lol
June '12 COTM
'95 AT200
post Mar 29, 2011 - 5:36 PM
Con99vert
Joined Aug 27, '09
From Las Vegas
Yes, I pull the lever, I hear it open, but by the time I walk back to the trunk it is completely closed and locked. I checked it out when I got home today and fixed the problem. The trunk lid has two rubber bumpers that should have just enough tension on them when the latch it pulled that it pops the trunk open enough to keep it unlatched. I guess over the years mine have either smashed a little too flat, lost some of their resiliency, or the metal on the trunk where they attach maybe got tweaked a little. There is no way to adjust them like on some cars so I used a pair of needle nose pliers to adjust the holes a little. I inserted the pliers into the holes and bent them out/down a little. Now the holes look like little upside down volcanoes. I reinserted the rubber bushings and now my trunk pops and stays unlocked just fine. Hope this helps somebody else in the future. A better way of doing it would be to just buy new rubber bushings, but this way worked just fine for now.
FOR SALE!!!
post Mar 29, 2011 - 8:52 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
i have the same problem on my gt celica what do I do???
post Mar 29, 2011 - 9:21 PM
coupes tend to do this due to the weight of the spoiler.
I dont use the trunk, and if i do, i use my key... I tried putting a stronger spring in there, it only worked for a week...
post Mar 29, 2011 - 11:46 PM
Con99vert
Joined Aug 27, '09
From Las Vegas
QUOTE (BonzaiCelica @ Mar 29, 2011 - 9:52 PM) *
read my post right above yours for the solution
FOR SALE!!!
post Apr 2, 2011 - 5:14 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
man! thanks! imma have to keep this in mind! ive been proping the latch inside the car open with my keys kindasad.gif
i been wondering why it was doing that! (this is all YOUR fault njccmd2002) wink.gif
post Apr 2, 2011 - 8:45 AM
Malek
Joined Jan 26, '09
From Los Angeles
Ghetto style: pull down your seat belt, loop it around the lever and pull it tight to hold the lever up. Problem SOLVED!
Just don't forget to unloop your seatbelt when you close the trunk lid/hatch biggrin.gif
post Apr 2, 2011 - 10:33 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
Ghetto style 2.0, keep one of those short fat little screw drivers on the floormat at all time to wedge in between the mat and lever.
Good fix con99vert!!
Lo-Fi Version Time is now: February 20th, 2025 - 12:14 PM
