> quick reverse glow question, wiring
post Dec 7, 2003 - 3:16 AM
van95st
Joined Sep 6, '03
From Fairbanks AK
where's the best place to tap off for the power on the reverse glow gauges? got em in just wanna make sure that i get the wiring right. and the black wire just needs to run to ground right?
post Dec 7, 2003 - 3:50 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
ya man the black is just a ground wire.
i tapped into my dimmer switch that way i could dim the gauges if i wanted to.
post Dec 7, 2003 - 3:02 PM
FallenHero
Joined Dec 26, '02
From Alabama
I ran both wires to the dimmer as well.
post Dec 7, 2003 - 3:54 PM
Ideally, you should use a SPDT relay to tap into a circuit to power a device such as indiglow gauges. You'd use a SPDT automotive relay, and hook up the terminals as follows.
85 - Wire that gets +12 volts when parking lights are on, such as dimmer wire. I know that with some kinds of indiglo wires however, giving them less voltage than 12 volts will make them not work.
86 - Ground(chassis ground, not the ground wire of the indiglow gauges)
30 - Fused +12 volt power from battery/power distribution block
87 - Power wire of indiglow gauges
post Dec 7, 2003 - 11:00 PM
van95st
Joined Sep 6, '03
From Fairbanks AK
ok the guages came with their own dimmer knob and switch, not power it switches them from blue to green. They also came with what i'm guessing is some kinda relay, it connects the power wires, the dimmer and the output to the gauges. The only other two wires are red and black.
post Dec 7, 2003 - 11:45 PM
QUOTE (van95st @ Dec 7, 2003 - 8:00 PM)
Then you'd use the information in my post above, and hook up black to a good chassis ground, and red to terminal 87. smile.gif
post Dec 8, 2003 - 1:34 AM
van95st
Joined Sep 6, '03
From Fairbanks AK
thanks coomer. prime reason i'm going for a m.e. degree instead of e.e. i really suck when it comes to anything electrical!!
post Dec 8, 2003 - 11:47 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
QUOTE (Neipas09 @ Dec 7, 2003 - 4:50 AM)
My gauges had a big warning about not getting power from the dimmer. It can burn out the transformer. The only safe way is to get power from the lead going to the dimmer knob not the controlled side coming out.
post Dec 8, 2003 - 1:09 PM
I powered mine from the lights going to the deck, turns on the stock deck lights.
post Dec 9, 2003 - 9:18 AM
van95st
Joined Sep 6, '03
From Fairbanks AK
i ended up tapping into the power coming from the light solenoid to the dimmer, and just grounded to chasis. thanks anyway coomer, if i knew what i was doing i woulda done it right. seems to be working ok though.
post Dec 9, 2003 - 1:24 PM
QUOTE (van95st @ Dec 9, 2003 - 6:18 AM)
Honestly, that's really not too bad of a way to go. Using a SPDT relay to tap into a circuit to draw power is better, but indiglow gauges really don't draw much power. wink.gif
Lo-Fi Version Time is now: January 17th, 2025 - 1:35 AM
