Please Help? |
Please Help? |
Mar 30, 2011 - 9:41 AM |
Enthusiast Joined Oct 23, '09 From boston Currently Offline Reputation: 0 (0%) |
so yesterday i put in subwoffers, they worked for about 5 min then i shut off the car. disconnected them, now the car wont start at all. batterys good, fuses are good, not sure about relays, dont know how to test them, but when i try to start the car nothign but silence, not even cranking. i tested the battery with a DMM and its a good battery, BUT when i put the keys in the car noting happens, not even getting power to locks,radio,lights,anythign. NOTHING at all happens. anyone know whats up? Thanks
Mar 30, 2011 - 10:20 AM |
sounds like you definatly blew a fuse or your battery isn't connected.
Check the terminals and make sure they're tight. I would guess checking the big fuses in the bay, starting with the 100a alt fuse. -------------------- |
Mar 30, 2011 - 10:37 AM |
Fusible link needs to be replaced. any idea on how to do it? or does this HAVE to be done by a tech?
Mar 30, 2011 - 11:26 AM |
yeah you blew the main fuse link. its under the hood in teh fusebox. its very easy to change and its the largest fuse in there
Mar 30, 2011 - 8:59 PM |
Fusible link needs to be replaced. any idea on how to do it? or does this HAVE to be done by a tech? some help http://www.6gc.net/forums/index.php?showtopic=65656 http://www.6gc.net/forums/index.php?showtopic=75306 -------------------- |
Lo-Fi Version | Time is now: November 30th, 2024 - 5:13 AM |
