> Clutch pedal has become very limp, and has stuck to the floor a couple times
post Apr 2, 2011 - 5:03 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
How do I check the clutch fluid?
post Apr 2, 2011 - 5:41 PM
Check the resivour attached to the firewall by the brake master cylinder.
Chances are the clutch master cylinder is going/ is bad.
post Apr 5, 2011 - 10:45 AM
conus00
Joined Jul 10, '08
From Tampa, FL
Good thing is that replacing master cylinder on Celica is piece of cake.
'94 ST
post Apr 5, 2011 - 11:00 AM
EKAn
Joined Apr 24, '07
From CA
Agree with above, same thing happened to me, switch the cylinder out and its been good ever since
what hes saying is if you put blue lights in you car youll lose hp.
post Apr 16, 2011 - 12:23 AM
enderswift
Joined Jul 12, '08
take it from me and buy toyota oem. I tried parts store masters a bunch of times and they've all failed.
post Apr 16, 2011 - 9:51 AM
azian_advanced
Joined Apr 18, '05
From Calgary
rebuild the slave cylinder too for good measure. the oem kit only costs $10 and 30 mins (or less) of your time.
post Apr 19, 2011 - 9:27 PM
Mycurse180
Joined Dec 23, '10
From PA, USA
Thanks for the info guys.
I'm in kind of a weird boat here. I'm having this problem [which I take it is the master cylinder going bad] but I also have rattling from the throw out bearing. I know it's TOB because rattling stops when I push in clutch pedal.
The clutch itself grabs fine though and it doesn't slip.
What do?
This post has been edited by Mycurse180: Apr 19, 2011 - 9:28 PM
Lo-Fi Version Time is now: February 22nd, 2025 - 2:50 AM
