ST204 5SFE PROJECT, boost , paint, rebuild |
Dec 22, 2012 - 8:13 AM |
Enthusiast Joined Feb 27, '11 From trevorton pa Currently Offline Reputation: 0 (0%) |
Booo... Another 3S swap... what were you using to tune the turbo 5SFE? lol yea im going to miss the 5s for sure but in the long run it will all be worth it ..... { tuning } my 5sfe i was using a 12:1 fmu . the cheap way to boost a car hers a link to show you http://www.ebay.com/itm/BLOX-RACING-FMU-FU...317&vxp=mtr This post has been edited by TRD11: Dec 22, 2012 - 8:15 AM -------------------- cant stop wont stop
Dec 22, 2012 - 10:08 AM |
Sadly that's not a tuning solution That's how you blow up a 5s.
That also doesn't have a way of tuning timing, so you were running on the stock timing tables which are too aggressive for forced induction. Going 3S will only be worth it if you leave it stock, but if you plan on upgrading without getting an ECU to tune for the upgrades you'll blow it too and then it'll just be a more expensive blown engine. Just some advice What do you plan on doing with the 5S stuff (engine parts and etc)? This post has been edited by Syaoran: Dec 22, 2012 - 10:17 AM -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Dec 22, 2012 - 11:04 AM |
its too late now but u should have used a head gasket from a 98 camry. its a metal gasket, not a fabric one
Dec 22, 2012 - 8:00 PM |
Sadly that's not a tuning solution That's how you blow up a 5s. That also doesn't have a way of tuning timing, so you were running on the stock timing tables which are too aggressive for forced induction. Going 3S will only be worth it if you leave it stock, but if you plan on upgrading without getting an ECU to tune for the upgrades you'll blow it too and then it'll just be a more expensive blown engine. Just some advice What do you plan on doing with the 5S stuff (engine parts and etc)? well that hasn't bin my problem with the 5s air fuel ratio ran 11 on 5 psi all day every day it was just that the millage is getting up there ....over 200.000 and i had a problem with the head gasket because i had boost spike a couple time over 25 psi because of my wastegate sticking .. /// not planing on doing much with the 5sfe so i can get rid of it -------------------- cant stop wont stop
Dec 22, 2012 - 8:03 PM |
its too late now but u should have used a head gasket from a 98 camry. its a metal gasket, not a fabric one i never new that thanks for the advise ill keep that in mind if i get a daily -------------------- cant stop wont stop
Lo-Fi Version | Time is now: November 27th, 2024 - 1:53 PM |
