> broken axle? need help
post Apr 5, 2011 - 12:23 PM
SynysterSt204
Joined Jan 1, '10
From Florida
so the car turns on and goes into gear smoothly with or without the clutch. but the problem is the car wont move.. any input?
post Apr 5, 2011 - 1:38 PM
malecrod
Joined May 30, '05
From MN
Car should go into gear only when you depress the clutch while it is on/running. Sounds like your clutch is out. Hopes that helps.
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Apr 5, 2011 - 2:52 PM
SynysterSt204
Joined Jan 1, '10
From Florida
QUOTE (malecrod @ Apr 5, 2011 - 2:38 PM) *
dont think its the clutch bro. i just changed it out recently but im pretty sure its either has to do with the axle or the cv joint . i can see it underneath the car i just wasnt too sure so i was looking to get some input
post Apr 5, 2011 - 3:03 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE (SynysterSt204 @ Apr 5, 2011 - 2:52 PM) *
how can you get the car in gear without putting the clutch in? maybe you forgot to hook up the shift linkage.
post Apr 5, 2011 - 7:49 PM
zfjohnson07
Joined Apr 11, '09
not the axle mine was cracked and still moved, drove it 1000 miles like that. so guess again
post Apr 5, 2011 - 8:09 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
either you shift cables are not connected or your clutch is permanently engaged...it should not go into gear without the pedal pushed
ST205 Crew represent
Challenge Accepted
post Apr 5, 2011 - 8:15 PM
greenhornet94
Joined Mar 20, '11
From Milwaukee
Yea it's your clutch. Happened to my buddies Cobalt. His was burnt up
post Apr 5, 2011 - 10:29 PM
SynysterSt204
Joined Jan 1, '10
From Florida
QUOTE (greenhornet94 @ Apr 5, 2011 - 9:15 PM) *
hmm idk how it could be the clutch i JUST replaced it not too long ago. well it was raining and i didnt get to really get underneath and look im gonna take a look tomorrow and find out whats what kindasad.gif
post Apr 6, 2011 - 7:32 AM
czwalga
Joined Sep 27, '10
From pittsburgh
Could have been installed wrong, faulty clutch, there could be many reasons.
The pivot point on your clutch fork could have broke, regardless I doubt it's an axle. Could be but I doubt it, the car does have an open diff so if the axles broke you wont move but there would probably be some resistance going into gear without the clutch.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Apr 6, 2011 - 9:21 AM
SynysterSt204
Joined Jan 1, '10
From Florida
QUOTE (czwalga @ Apr 6, 2011 - 7:32 AM) *
well i got underneath today and from what i saw the front driverside axle is broken.gonna get it swapped out and hopefully back on the road soon. i appreciate everyones input and hopefully it really isnt the clutch kindasad.gif
post Apr 6, 2011 - 11:34 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (SynysterSt204 @ Apr 6, 2011 - 10:21 AM) *
You can check, jack the car up. Have someone put it in first gear, if the broke axles is spinning right by the transmission its just the axles and not the clutch.
-10 F150
post Apr 6, 2011 - 10:56 PM
SynysterSt204
Joined Jan 1, '10
From Florida
QUOTE (czwalga @ Apr 6, 2011 - 11:34 AM) *
yea thats exactly what it was
Lo-Fi Version Time is now: November 27th, 2024 - 11:30 AM
