> FS: Various Unused Toyota Parts
post Apr 5, 2011 - 9:12 PM
RedRkt01
Joined Jun 1, '08
From STL
So far this is what I've available:
ST202/4 Tranny Mount 12372-74451 (S54) $74.17
ST202/4 Rear Mount 12371-74411 (S54) $49.03
ST202/4 Rear Bracket 12321-74321 (S54) $34.32
ST202/4 Timing Side Bracket #1 12315-74130 $77.66
ST202/4 Timing Side Bracket #1 Bolts (3) 90119-10599 $3.72
ST202/4 Timing Side Bracket #2 12316-74070 $31.74
ST202/4 Timing Side Stabilizer 12381-74020 $9.49
I have a used ST202/4/5 PS High Pressure Hose 44410-2B030. Perfect condition. I'm open to offers.
I have a used ST202/5 Speedometer Gear/Sensor for E Series transmissions 83181-12050. Perfect condition. I'm open to offers.
For those of you running 2nd or 3rd Gen 3SGTEs:
SW20 MR2 TRD Metal Head Gasket PTR04-17910-01 (11115-SW201) $84.40
SW20 93-97 MR2 TRD Plug Wires PTR04-17920-02 (19051-ST811) (should work for all 2nd Gen 3SGTEs as well, CMIIR) $136.05
And for those of you wanting to squeeze a bit more power out of your 5SFE:
ST202 3SGE OEM Exhaust Manifold (4-2, should work for all you 5SFE folks) $65
PM here or on Ctech if you're interested in any of this stuff.
Cheers,
RedRkt01
This post has been edited by RedRkt01: Jul 28, 2011 - 1:36 PM
post Apr 6, 2011 - 7:33 PM
RedRkt01
Joined Jun 1, '08
From STL
Bump.
post Apr 11, 2011 - 10:57 AM
RedRkt01
Joined Jun 1, '08
From STL
Bump!
post Apr 12, 2011 - 10:36 PM
RedRkt01
Joined Jun 1, '08
From STL
Bump!
post Apr 18, 2011 - 2:59 PM
RedRkt01
Joined Jun 1, '08
From STL
'nother bump!
post May 10, 2011 - 10:34 AM
RedRkt01
Joined Jun 1, '08
From STL
New month bump.
post May 10, 2011 - 11:35 AM
mkernz22
Joined May 10, '10
From MA
is it a definite fit on the 5sfe with the header?
post May 11, 2011 - 10:37 AM
RedRkt01
Joined Jun 1, '08
From STL
QUOTE (mkernz22 @ May 10, 2011 - 12:35 PM) *
What year is your 5S?
post May 11, 2011 - 10:57 AM
WHATxTHExTIFF
Joined Feb 6, '11
From TORRANCE
I have a 95 celica gt 5sfe will the 3sge manifold fit and is it a direct bolt on?
post May 11, 2011 - 11:45 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Redrkt01, are you still able to get the poly-urethane pushings you used to sell on celicatech?
My Celica!
post May 11, 2011 - 3:42 PM
RedRkt01
Joined Jun 1, '08
From STL
Through Superpro yes.....not through Poland.
QUOTE (WHATxTHExTIFF @ May 11, 2011 - 10:57 AM) *
I need to find a 5S gasket to see if it matches up......I believe I've done this before so I think it works, but I have to make sure as I'm not positive.
post May 12, 2011 - 10:33 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Pm'd about plug wires
2001 Solar yellow Lexus IS300
post Jul 26, 2011 - 6:08 PM
RedRkt01
Joined Jun 1, '08
From STL
ttt
post Jul 28, 2011 - 12:24 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
is the speedo gear the one on the diff or the sensor?
post Jul 28, 2011 - 1:01 PM
RedRkt01
Joined Jun 1, '08
From STL
QUOTE (stephen_lee @ Jul 28, 2011 - 12:24 PM) *
Both....sort of. It is the sensor which takes its reading from a gear on the end of it. That gear on the end mates up to a plastic ring gear in the diff housing.
A picture of what it is can be seen in this ebay listing: http://cgi.ebay.com/ebaymotors/93-95-SW20-...=item2565eba9a8
You can also search the part number that I listed.
This post has been edited by RedRkt01: Jul 28, 2011 - 1:29 PM
post Jul 28, 2011 - 4:34 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
So the whole speed sensor assy?
post Jul 28, 2011 - 4:48 PM
RedRkt01
Joined Jun 1, '08
From STL
I'm not really sure what you're asking here. Between the the picture and the part number I think you should be able to know if what I'm selling is indeed what you want. What I'm selling is exactly what's in the ebay listing. If that is what you need, then that is what I can provide you with.
post Jul 28, 2011 - 4:55 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Wanted to be perfectly clear. I'm on a phone so the pic was small.
post Jul 28, 2011 - 5:47 PM
RedRkt01
Joined Jun 1, '08
From STL
QUOTE (stephen_lee @ Jul 28, 2011 - 5:55 PM) *
Gotcha. Yeah, this thing gets shoved into the diff box and bolted into place. Then a three plug electrical connector snaps onto it giving you your speed reading.
post Jul 28, 2011 - 6:24 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Ah, I see. I needed the one on the diff. Thanks!
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 23rd, 2025 - 12:14 PM
