> Fogs stopped working, relay?, What could be wrong
post Apr 11, 2011 - 2:20 PM
Cs91
Joined Oct 16, '09
From Norway
My car just stood still this winter and I just took it out, everything works fine and it started perfectly and everything, but my fogs have stopped working!
I´ve checked the fuse, not blown. Someone tipped me that it could be the relay for the switch? Then were is it located and how can i fix it?
Is there also an easy way to check if the bulbs havent both blown?
The car is a 96 ST facelift.
Thanks C.s
And yes, i tried searching....
post Apr 14, 2011 - 5:53 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Have a look in your engine bay, but I cant remember ever seeing a separate relay for fogs.
I have had both fogs blow at once though - multiple times.
you need 10mm socket and extension and a rat****
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: February 13th, 2025 - 6:31 AM
