> 14-pin plug to 22-pin wiring, Does anyone know?
post Apr 15, 2011 - 12:29 PM
atmosfear
Joined Sep 20, '10
From Kansas City, MO
Hey all, I've got a 91 GT hatch w/3sgte swapped in. Everything is beautiful, harness looks great, etc. My only problem is the 3rd ecu plug integration, the 14-pin 5sfe to 22-pin 3sgte. I don't have any idea what goes where, or how to splice them. I've been in contact with phoenix tuning (tweakd performance) for weeks, they (cam) was supposed to send me a diagram on exactly what wires go where, but I've gotten nothing. I need to know how to wire this, as its all I need to be up and running. I've gone over the pinouts countless times, and still don't know. Do I match +b to +b, els to els, etc? I know something has to be tee'd into the circuit opening relay, but what, starter wire? this is a fairly popular swap, someones gotta be able to help. Thanks in advance.
post Apr 18, 2011 - 7:44 PM
atmosfear
Joined Sep 20, '10
Seriously? All the swaps on here and noone knows? Hmm.
post Apr 23, 2011 - 4:22 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Are their only 13 wires that are used on that 22-Plug?
SPD = Speed sensor from transmission hook it up to the old wire that says SPD
B and B1 = are from the EFI main relay.
Batt = 12v+ hooked to 15A fuse.
AC1 and ABS can be left out if you don't have ABS or aren't planning to use A/C system.
W is for check engine light.
FPR on the 3sgte can be left out, but you would have to check and see if your fuel pump is running wen your cranking.
I don't know which wiring your using nor if you spliced the 3sgte into the 5sfe a little more detail would be nice
Lo-Fi Version Time is now: December 2nd, 2024 - 12:03 AM
