> JDM Sidemarker/Repeater Wiring Question, ... please help, wiring gurus.
post Apr 18, 2011 - 2:27 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
So I've read through this article: http://www.6gc.net/howto/install_jdm_sidemarkers which has been very informative.
However I have a question regarding the blinking pattern of the front turns, and the jdm sidemarkers...
I want the Sidemarker to remain off until I'm signaling; at which point I want them to blink opposite the front turns.
For example; when the front turns are lit - the sidemarkers aren't and vice versa...
What wires do I hook up where to get this to work?
post Apr 18, 2011 - 10:06 PM
mkernz22
Joined May 10, '10
From MA
I believe that you would have to wire a bunch more in. From what I know, the blinker relay would have to send power to one, then switch to the other one and so on to create that effect. I bet Dustin (batman722) would know more on how to do this. It could be very easy, but I know since our cars are not setup for it, you would have to run extra wires and rewire a few things.
post Apr 21, 2011 - 11:33 PM
96ST206
Joined Jan 6, '08
From Oak Ridge TN
I wired mine to my stock blinkers, but I think they werent alternating. Yea the sidemarkers are supposed to be off until you turn on the blinker. Don't be " omg mad tyte jdm yo" and have them always on l laugh.gif
If anyone needs info on the Toyota Curren feel free to PM me!
post Apr 22, 2011 - 12:58 AM
KAOS
Joined Apr 18, '06
QUOTE (96ST206 @ Apr 21, 2011 - 10:33 PM) *
I don't want them to be on all the time, I just want them to alternate with the fronts...
post Apr 22, 2011 - 5:35 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
time out, let me see if i get this, you want the front to blink, then you want the sides to blink correct?
Easy souloution, run a relay and for the switch side run it to where the turn signal power goes on and wire up everything else accordingly, should take a second for the relay to kick in
2001 Solar yellow Lexus IS300
post Apr 23, 2011 - 7:59 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Yeah best bet would be adding a couple relays and rewiring, one circuit open one circuit closed kind of relay
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: November 27th, 2024 - 5:26 AM
