![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) ![]() |
New: Do I need ALL the GT mounts to swap into an ST? Or tell me which ones I will need
Will be using the GT transmission. I can get the cables, but are the shifters the same? or do I need one from a GT? thanks Thanks just need to know what to buy Ok so I bought Jims alltrac 3sgte, that manny installed, and did all the work to (timing belt, seals, ect.) so all thats already done for me (yeah i got super lucky ![]() It comes with an ACT 6 puck clutch installed. I was debating on the e153 trans, but have decided to go with the stock GT trans, just to get it done sooner. maybe Ill go that route later. This post has been edited by mgnt232: May 13, 2011 - 7:02 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) ![]() |
not to sure about the ST trans.. idk if people have used them but to me, it doesnt seem like a good idea. i think your better off buyin the GT trans lol. as for the "custom" part, that would be your clutch, its called a "hybrid" clutch because you need the 5s disc and the 3s flywheel and pressure plate.
This post has been edited by Ted95: Apr 24, 2011 - 4:19 PM -------------------- st205 powered ss3 coupe
no no im going to use the s54 trans (sorry my post was prob confusing, Im just most likely using an ST shell). So as long as I have the 5s tranni and the 3s flywheel, im good? For some reason I thought there was something else
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
you need a 3S pressure plate with a 5S disk. Southbend clutch can also make you a 3S clutch set with the 5S-FE splines in the hub of the disk. all you have to do to install is follow the 3S-GTE in an ST guide. you need to drill and tap the holes in the frame to support the engine mounts
ok so will the ACT 6 puck clutch with the engine work?
also I just found my GT swap car! hopefully picking it up this weekend! ![]() -------------------- |
you better have this thing ready by CSP
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) ![]() |
Bah I was batting for that engine too.
Still got a set coming either way. Gratz! Eager to see future posts of progress. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) ![]() |
Get a s54 stage 2+ disk, everyone around here swears by the s54 splined 3sgte disk but its literally only like a 1/4" difference, not worth that extra 200$ IMO.
sooo will the ACT 6 puck clutch work (it worked with the e153 in the alltrac i think) but will it work with the s54? thats what its coming with, or do i need to buy a new one too
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
the splines on the alltrack clutch are different and will not go on your s54 trans
So I can just buy a 5s stage 2+ disk. I DO NOT need to get a custom splined 3s (splined to an s54) disk. I mean will it work? If it will great, if not the $200 isnt a big deal. I dont want to buy something that isnt going to work lol
I assume the 3s will come with a 3s flywheel and pressure plate, or i can get some from jim when i pick it up. And would just use the 5s alignment tool right? thanks alot everyone, its been a while since i even did my 7a clutch, its coming back slowly now though lol This post has been edited by mgnt232: Apr 22, 2011 - 4:01 PM -------------------- |
bump new question at top
all GT mounts/brackets except the front mount.
This post has been edited by Batman722: May 13, 2011 - 10:20 PM -------------------- |
Alright good to know, thanks a ton
Lo-Fi Version | Time is now: February 25th, 2025 - 12:23 AM |
