turbo gen 3 3sge |
turbo gen 3 3sge |
Apr 20, 2011 - 11:18 AM |
Enthusiast Joined Feb 3, '11 From jamaica Currently Offline Reputation: 0 (0%) |
hi guys been a silent browser for sometime now love your club.
i have tried what is not recommended turboed a gen3 3sge i have installed in my 89 camry. my car is daily driver so i want to run low boost 7-10 lbs. somehow my car seems to not able to boost past 2 lbs and thats like on the highway. have check for boost leak not seeing any.i have resort to a ebay turbo after trying ct26 a kkk that smoked none stop. i am using a external turbo xs with 5 lbs spring wastegate with hks boost controller,tube manifold fmic 2 1/2 piping ,stock injectors stock ecu. any idea as what could be my problem This post has been edited by gtprominient: May 12, 2011 - 9:32 AM |
Apr 20, 2011 - 11:23 AM |
Enthusiast Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) |
Sounds like a boost leak, you said you checked but I would double check behind every coupler and clamp...you'll find it
Apr 20, 2011 - 6:46 PM |
Enthusiast Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
wastegate flap getting stuck open perhaps.
how big is your exhaust? what ecu? -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s |
Apr 20, 2011 - 9:44 PM |
Apr 21, 2011 - 6:18 AM |
you say you only get a couple of psi, what revs do you get those psi? low or high.
If low its possible your exhaust is just too restrictive to allow enough flow to give reasnable boost. If high its possible your wastegate flap isnt closing properly and just letting exhaust gas bypassthe turbine wheel. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Apr 22, 2011 - 1:20 AM |
do u have a 3s-gte map sensor? i dont know that the 3s-ge vacuum sensor can even read boost past 2 psi
-------------------- Mike W
Apr 24, 2011 - 9:17 AM |
you say you only get a couple of psi, what revs do you get those psi? low or high. If low its possible your exhaust is just too restrictive to allow enough flow to give reasnable boost. If high its possible your wastegate flap isnt closing properly and just letting exhaust gas bypassthe turbine wheel. Sorry for the for the delay was away for sometime i get the the boost at very high rpm in the five grand region.have a external wastegate no i do not have a 3s gte map i have a stock 3sge map the car revs to 7s without a problem |
May 12, 2011 - 9:43 AM |
found the problem was a boost leak at that hose coming off the mouth of the turbo thanks guys.next problem the turbo has a little oil in the front housen is that normal doesnt smoke when driving could the stock exhaust piping cause that
Jun 9, 2011 - 4:43 PM |
Enthusiast Joined Oct 20, '08 From Lima,Peru Currently Offline Reputation: 0 (0%) |
are u running on stock ecu?
im planning to turbo my 3sge too because we cant import 3sgte's anymore =/ some stupid law |
Oct 29, 2011 - 4:27 PM |
Oct 29, 2011 - 4:33 PM |
are u running on stock ecu? im planning to turbo my 3sge too because we cant import 3sgte's anymore =/ some stupid law sorry for the delay yes but hoping to change that soon i am using some ngkiridium 8 spark plugs any idea what i should gap them |
Oct 29, 2011 - 5:08 PM |
Enthusiast Joined Dec 30, '10 From amarillo texas Currently Offline Reputation: 6 (100%) |
all ngk iridium plugs come pre-gaped. they can be gaped but it is not recommended to gap them because they are so thing they will break easily.
Oct 29, 2011 - 10:19 PM |
Depends on how much "a little oil" is, second hand or cheap turbos will often leak a bit of oil.
Another (but unlikely reason if the turbo is bush bearing) is there is too much oil pressure and its pushing out past the seal. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Oct 30, 2011 - 6:52 AM |
all ngk iridium plugs come pre-gaped. they can be gaped but it is not recommended to gap them because they are so thing they will break easily. thanks i will leave them as is. Ii did a compression test yesterday and the no.1 cylinder was lower than the other 3 no.1 was 165lbs the others 175lbs is that normal |
Oct 30, 2011 - 6:59 AM |
Depends on how much "a little oil" is, second hand or cheap turbos will often leak a bit of oil. Another (but unlikely reason if the turbo is bush bearing) is there is too much oil pressure and its pushing out past the seal. i got a thing to reduce the oil pressure and it is okay now do u think i should remove the pcv that run from the toppit cover to intake manifold? can i put a oil catch can there |
Lo-Fi Version | Time is now: November 23rd, 2024 - 7:29 PM |
