Radiator Fan/Temp Sensor/AC |
Apr 20, 2011 - 4:32 PM |
Enthusiast Joined Apr 29, '03 From lynn,ma Currently Offline Reputation: 0 (0%) |
Tons of problems...
Ok my temp sensor is weird... it takes forever to go up but doesn't go to normal....(halfway between H and C) it stay like at like 3/4 area between middle and C, sometime it goes up...close to Middle. When I check my car, I notice the radiator fan is also not moving at all, even on really hot days and than my A/C doesn't work... it turns on, the fan inside the cabin blows warm/hot air instead of icey cold one. any idea what's going on, and what's the first step to trouble shooting this? I am thinking the thermostat need to be replaced.... but where is it located? thanks ahead of time ^_^ |
Apr 20, 2011 - 10:34 PM |
Enthusiast Joined Mar 26, '10 From Portsmouth, OH Currently Offline Reputation: 2 (100%) |
sounds like your engine cooling system is working fine (mine never reaches halfway even when running hard on hot days) and your A/C system needs some freon... may have a leak in there or something.
Apr 21, 2011 - 12:47 AM |
sounds like your engine cooling system is working fine (mine never reaches halfway even when running hard on hot days) and your A/C system needs some freon... may have a leak in there or something. Don,t know if the cooling system is fine or not cuz it use to go mid way.... I am sure the radiator fan should be running... o_O I order the thermostat anyways and see if that change anything. I tried one of those charge bottle for the A/C but the gauge read it's at full? Not sure, it turns on, but doesn't blow out cold air... I'll look up how to check the a/c system i guess |
Apr 22, 2011 - 2:47 PM |
AC needs to be re-gassed perhaps, does the compressor still work though? does it make your engine feel heavy still when you turn it on.
sounds like your thermostat is stuck open too, follow the bottom radiator hose to the block, what that hose is connected to is the thermostat housing. use long nose bent pliers to pull off the clips and remove the lower radiator hose, theres also a drain plug down there if u need to do it cleanly. use 10mm long socket with extension to remove thermostat housing, go to toyodiy and get the p/n for your thermostat AND thermostat gasket, take the 2 part numbers to toyota, and then reverse the removal process. top up radiator with 50/50 solution of whatever coolant you were using in the first place, run the car until up to normal temp and top up radiator as necessary, then go for drive -------------------- Mike W
Apr 22, 2011 - 2:51 PM |
radiator fan wont run even if its a hot day as your engine isnt even reaching operating temperature.
Apr 23, 2011 - 2:49 AM |
Apr 23, 2011 - 8:38 PM |
With your AC it could be the circuitry or even the compressor itself.
The AC compressor should still turn on this is what I'm thinking. -------------------- Mike W
Apr 26, 2011 - 10:29 PM |
hmmm any way to check if the ac compressor turn on or not?
May 23, 2011 - 7:25 PM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
When you turn your A/C on full blast does your electrical fans cut on? If not did you check your CDS fuse (Pink 30AMP fuse, first one)? Could be something as simple as that.
Lo-Fi Version | Time is now: January 11th, 2025 - 5:36 AM |
