> TRD COILOVERS
post Apr 24, 2011 - 10:32 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
when i got my car a while back it has J Speed Coilovers on it. at least on in the rear is blown maybe both, and they bounce really back. i hit the track a couple weeks ago and i kept bottoming out really back so i decided to get a different set. i came across a set of TRD Coilovers i just won them on auction tonight and currently waiting for them to get shipped so i can check them out. i really hope they're in good condition. i figure i can get a set of adjustable pillow ball mounts and be good to go. any one know for sure if there are adjustable damper, and if i could send them off to toyota to have them rebuilt if i need to?
post Apr 24, 2011 - 10:35 AM
Culpable04
Joined Apr 17, '06
From New Jersey
you would have better luck rebuilding the Jspeed coilovers, I think TRD stopped making parts for those coilovers a while ago, and the TRD damper is only 4 way adjustable, so you would only have 4 settings on each coilover, that's not ideal for fine tuning your suspension for the track.
post Apr 24, 2011 - 1:12 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
you might be wrong Culpable. I contacted toyota trd about 5 months ago about getting cartridges for the ST202 Superstrut TRD Coilovers. I'm pretty darn sure that trd makes a set of brand new coilovers for the GT-4 at $3,200 when I last checked. So I would only assume that they would have the cartridges brand new still readily available to purchase. They will not be cheap to buy, because these shocks aren't rebuild-able, you need to buy brand new cartridges. Last I checked they were $1,500 for the cartridges alone for the ST202.
This post has been edited by BonzaiCelica: Apr 24, 2011 - 1:16 PM
post Apr 24, 2011 - 2:49 PM
FORGMANN
Joined Dec 11, '04
From USA
Koni North America is located 20min from me and has a service center that can convert Non-Koni shocks and do custom setups..
I am going to look into this option and see what cost will be. Update in my project thread when i found out..
I have 3 set of TRD coilovers and might be cheaper to get them all done at once..
Old guy with the toys
95 ST205 WRC (the real deal)
94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned
post Apr 24, 2011 - 2:52 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (FORGMANN @ Apr 24, 2011 - 2:49 PM) *
I believe I remember trying to contact koni about their custom setup and they said they wouldn't!!! are you sure about that??? Since koni does already make the yellow adjustable shocks for our 94-99 celica the insert is the same size for Superstrut and Macpherson size cartridge inserts. Please find out for me I would greatly appreciate it.
post Apr 24, 2011 - 3:03 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Just FYI i checked with toyota about 8months ago through Bill at B&M, and the qoute i got for a rebuild for a set of TRD coilovers was around 1000 bucks...TO be honest man i think your best bet would be to invest in a BC set, as 1000 for a rebuild is rediculous...
(\__/)
post Apr 24, 2011 - 4:33 PM
Rusty
Joined Nov 5, '07
From New Zealand
You can still adjust the damper via the top nut (1~4). TRDGT4 has tracked his GT-Four many times, and as far as I'm aware hes had no issues with them
Interesting enough Bonzai...
ST20# English TRD website version
ST20# Japanese TRD website version
(生産中止 = Discontinued)
If you are thinking of rebuilding them
Height Adjustable Suspension KIT Component Part (48000-ST0B0)
FR Shock Absorber 48511-ST050 G 2 4-stage adjustabel rate 3244/1049N
RR Shock Absorber 48531-ST050 G 2 4-stage adjustabel rate2509/833N
FR Shell Case RH 48021-ST070 G 1 Height Adjustable Type, RH
FR Shell Case LH 48029-ST070 G 1 Height Adjustable Type, LH
RR Shell Case RH 48508-ST070 G 1 Height Adjustable Type, RH
RR Shell Case LH 48509-ST070 G 1 Height Adjustable Type, LH
FR Coil Spring 48131-SP000-10 G 2 K=98.0N/mm、Free length: 185.0mm、Mark colour: Gray×1
RR Coil Spring 48131-SP000-08 G 2 K=78.4N/mm、Free length: 193.5mm、Mark colour: Brown×1
Spring Upper Seat 48471-SP014 G 4
Spring Lower Seat 48472-SP012-55 G 4 M55×2
Spring Lower Seat Retainer 40815-SP012-55 G 4 M55×2
FR Upper Support 48609-ST000 G 2 Extra firm type
RR Upper Support RH 48071-ST000 G 1 Extra firm type
RR Upper Support LH 48072-ST000 G 1 Extra firm type
RR Upper Support Collar 40846-SP002 G 2 t=9
Bump Rubber 48331-12130 G 4 Toyota Genuine Part
RR Shock Absorber Spacer 90387-15027 G 2 Toyota Genuine Part
FR Dust Seal 90303-22049 G 2 Toyota Genuine Part
not to be confused with these ones which are just shocks with damper adjustments
Front
ST20#(Super strut suspension)
48510-ST010 G 1
48520-ST010 G 1
Rear
ST205
48530-ST070 G 1
48540-ST070 G 1
post Apr 24, 2011 - 6:05 PM
BonzaiCelica
Joined Apr 24, '08
just so you guys get an idea and yes I know the value of the dollar vs the yen is only getting worse by the day...
these cartridges are so damn expensive!!!
This post has been edited by BonzaiCelica: Feb 26, 2013 - 4:21 PM
post Apr 25, 2011 - 6:36 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
so i was wondering since they are just cartridges, couldnt i just get a set of like koni cartridges or something just match the correct size with the table above and i should be good to go right?
post Apr 25, 2011 - 10:03 AM
3WayStunna
Joined Jun 25, '06
Thats a goo question. I also heard that the tein and TRD struts/cartridges are the same. Made by the same manufactuerer
(\__/)
post Apr 25, 2011 - 10:11 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (3WayStunna @ Apr 25, 2011 - 10:03 AM) *
you are wrong. Tein charges $75 to revalve/rebuild them while toyota TRD Coilovers are not rebuildable. TRD you need to buy the whole cartridge.
QUOTE (ST205WRC @ Apr 25, 2011 - 6:36 AM) *
like i said I tried before but I got nothing. Contact them again to see what they say you have all the info you need on sizing and dampening.
Lo-Fi Version Time is now: December 1st, 2024 - 9:15 PM
